Convertible Top Problem - Top Does Not Open
Old Jul 10, 2016 | 10:00 AM
Dharn55's Avatar
Dharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud of
On my 2000 C4 Cab the top stopped opening yesterday. The clam shell opens and the latch at the top of the windshield opens and then it stops. You can hear some clicking. When I run my Durametric it shows a fault code, 5 - maximum time exceeded. If I clear this error it re-appears.
A little background on this. Yesterday morning I used the RemoteTop on the car to open the top and it opened about 6" then stopped. This had happened a couple of time recently. When I got in the car and used the dash switch the top opened all the way. We went to the farmers market and used the dash switch, with the one touch option using a SmartTop module and it closed fine. When we returned to the car and used the RemoteTop/Key to open the top only the clam shell raised the the windshield latch opened and nothing else. then tried the dash switch with the same result. Top closes all the way with the key or dash switch but does not open.
This car has a SmartTop that was installed 10+ years ago. Also a RemoteTop that was installed 6+ years ago, the original style without the separate power feed, which failed about 2 years ago and was repalced with the newer version that has the separate power feed. This worked well until a month or so ago when the top started opening almost all the way and would stop just short of closing the clam shell. I spoke to Mods4cars and they had me reset the timing by starting the opening procedure, pushing the windshield micro switch withing 8 seconds of starting, and pushing it again one the top was down and before the windows raised. This seemed to fix the problem. Also the top was replaced 3 months ago but has worked fine up until now.
I tried to recalibrate the the top with the Durametric and nothing would happen, I had tried this in the past. I removed the RemoteTop and the problem still existed. Then I removed the SmartTop module and the problem still existed.
But here is something interesting, when the SmartTop module was removed the Durametric recalibration worked!! AT least it started, but stopped at the same point, Clam Shell Open and windshield patch open, then stops. Same error code shows up, max time exceeded. There are no error codes for bad micro switches.
I have check the oil level, it was slightly low, and refilled it. No leaks or anything else. Checked micro switches for the clam Shell, top mounted latch assembly, and windshield assembly and all seem to work, although I have not ohmed them.
It seems that once the clam shell is opened and the latch opens, there is come clicking but the pump doe not start and the top does not move.
Looking for suggestions on what to look for. I know this is a little long but I wanted to give as much information as possible.
sosdon
Apr 8, 2016 01:14 PM
AMG-ETR
Aug 6, 2003 07:50 AM
02barebones996
Jul 22, 2003 10:03 PM
GaryD (UK)
Jul 21, 2003 04:07 PM
