Need help with part name and #..
Old Nov 10, 2016 | 03:29 PM
nottoshabi's Avatar
nottoshabi is infamous around these parts
Its the whose that connects to the throttle body and to the filter on screen left. The hose is old and worn out and i can not read the part number on it and would like to replace it before its starts to leak. Also do you think it will be wise to replace the filter as well?
Old Nov 12, 2016 | 10:53 AM
dporto's Avatar
dporto is infamous around these parts
So, as seen here http://www.autoatlanta.com/porsche-p...section=107-10 part #'s 28 (hose) and 30 (vent line) are most likely part of the vacuum system. The "filter" you mention in your post (#30) is probably a valve as opposed to a filter. Unfortunately, it's a bit pricey - you should make sure it is indeed not operating properly before you replace it, otherwise you could be out $225 + shipping for no good reason. Good luck
Old Nov 12, 2016 | 03:13 PM
nottoshabi's Avatar
Thanks dporto. Will definitely double check the valve if it needs replacing. The hose on the other hand definitely needs replacing its starting to show real bad wear and tear and braking apart on the out side.
