tire pressure help
Old Feb 6, 2006 | 09:52 AM
redline C4s's Avatar
redline C4s is infamous around these parts
Exclamation tire pressure help
I was just wondering what my tire pressure should be. I have 19x9 inch wheels in the front with a 245/35 and my back is a 19x11 with a 315/25.
i am currently running 35 psi in the front and 40 in the back. I am not sure what to use and was wondering what others are using.
Thanks for any help since the search engine is down
Old Feb 6, 2006 | 11:44 AM
trovan's Avatar
trovan is just really nicetrovan is just really nicetrovan is just really nicetrovan is just really nice
if i remember correctly from the mechanic that put my tires on: 30 front/40 back.
Old Feb 6, 2006 | 12:39 PM
1999Porsche911's Avatar
1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future
With such a low profile tire, I would NOT run less than 44 in the back and 36 in the front.
Old Feb 6, 2006 | 01:59 PM
dice996c4's Avatar
dice996c4 is infamous around these parts
I'm running 36 in the front and 40 at the back.
Old Feb 6, 2006 | 03:04 PM
so the lower the profile the more pressure it needs?
also what size tires and wheels are you running dice?
Old Feb 6, 2006 | 03:19 PM
joekimdds's Avatar
joekimdds is infamous around these parts
38's in the front; 42's in the back
Old Feb 7, 2006 | 04:56 AM
03-turbo911's Avatar
Senior Member
Used to run that when I had my 19" wheels. As 1999Porsche911 said, I wouldn't run less than that with 19's.
Old Feb 7, 2006 | 01:51 PM
ZX9RCAM's Avatar
ZX9RCAM is infamous around these parts
I only have Kinesis 18's, but I am running 45# in the rear & 40# up front.
This is what the previous owner said to run in order to avoid damaging
the rims....
Old Feb 7, 2006 | 01:54 PM
Senior Member
the rims....
That's way too high in the fronts for 18's. I usually run around 34fr/38rr.
Old Feb 7, 2006 | 03:02 PM
ZX9RCAM's Avatar
That is about what I was running with the stock 18's, but the Kinesis rims
have lower profile tires on them....I think the back are 30 series.
Old Feb 7, 2006 | 08:21 PM
evo_333's Avatar
evo_333 is infamous around these partsevo_333 is infamous around these parts
in the manual it says to run 36 in the front and 44 in the rear... and that's for 18s
Old Feb 7, 2006 | 09:04 PM
yeah but i am running 19's so should it change?
Old Feb 7, 2006 | 11:44 PM
Senior Member
Run the factory 36/44 with 19's.
Old Feb 8, 2006 | 05:58 PM
are these cold temperatures?
Old Feb 8, 2006 | 06:25 PM
joekimdds's Avatar
should be cold...you could run couple miles with them before it changes
