Crazy idle issue, '99 c2
Old Sep 1, 2020 | 05:45 PM
Oldpenner's Avatar
Oldpenner is infamous around these parts
My '99 c2 has an issue that is driving me nuts. When driving, the idle of the car does not drop below 2300 rpm unless I leave it in gear and brake down to 1000 rpm or so, and then it will idle normally. As soon as I get back up over 2300, it not drop below that level, even between shifts. Problem seems worse when the engine is warm. Here is what has already been eliminated from the list of possible causes.
1) Air idle valve, replaced after finding crack in original
2) Mass air flow sensor - came up on CEL readout, so i replaced
3) Throttle Cables cleaned, checked for binding, junction box cleaned
4) Throttle body cleaned, spring checked
5) Smoke tested for vacuum leaks, found two and repaired.
6) Throttle pedal disassembled, cleaned and lightly lubed
7) Manometer reading at oil filler checked
None of the above has made a difference, if anything, it has gotten worse. I have posted quite a few threads at Rennlist, and I need to spread the net a bit wider to see if i can get lucky and catch the solution here! Several Rennlisters with the same year car also have the same problem. Eternally grateful to the sage who solves it!
Old Sep 28, 2020 | 09:25 AM
ttt123's Avatar
ttt123 is infamous around these parts
I had similar issue and it was a leak at the throttle body. maybe go back through a few of the things you already tried as those would be where I think most of us would have focused as well.
Yoghurtshotgun
Bentley
Jun 1, 2025 03:47 PM
AllanPac
Nov 28, 2017 01:34 AM
Jahre 40AE
Jan 2, 2015 06:31 AM
996TWINS
Sep 9, 2014 10:56 PM
GTIMAN99
Jul 13, 2012 08:43 AM
