The BIG fix, etc.
Old Aug 2, 2014 | 06:37 PM
996TWINS's Avatar
996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute996TWINS has a reputation beyond repute
The BIG fix, etc.
My car has been in the shop for some upgrades, fixes, and preventative maintenance. Here is the list in no particular order:
Coolant pipe fix
Expansion tank
Water pump
Check valves (I thought there was only one, but there are two)
Oil pressure sending unit
Metal turbo oil feed lines checked
Waste gate vacuum lines
5 bar fuel pressure regulator
Clutch kit
Slave cylinder (found it was leaking a bit with the engine removal. Bad news/good news)
Pressure accumulator
Spark plugs
Water hoses
Fuel filter
Air filter
Crankshaft seal
Boost pressure test
Wastegate adjust
Endless brake fluid
Coolant
Throttle body seal
Precision Porsche GT2 deck lid (wing painted matte black)
GT2 deck lid wiring harness
Transponder
Coil packs
Solenoid brackets
Engine mounts (RSS)
Trans mount (997 version)
Multi-rib belt
2nd gear detent
So after all this, no more thoughts about blowing a coolant fitting at the track.
Pulls like a freight train again. The shop owner had fun with "test" drives.
Old Aug 2, 2014 | 07:11 PM
'02996ttx50's Avatar
nice refresh. the car always loves when we care lol
Old Aug 2, 2014 | 09:15 PM
rmc1148's Avatar
Did you have pipes pinned/welded I didn't see that listed= may have missed.
Old Aug 2, 2014 | 10:08 PM
996TWINS's Avatar
Just like a mistress/girlfriend, the more you spend on her, the more she loves you!
Old Aug 2, 2014 | 10:09 PM
996TWINS's Avatar
The pipes were TIG welded.
Old Aug 2, 2014 | 11:23 PM
03EvoIII's Avatar
03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute
Have any pics??!!
Nice build!
Scot
Old Aug 3, 2014 | 12:46 AM
996TWINS's Avatar
Originally Posted by 03EvoIII
Have any pics??!!
Nice build!
Scot
Thank you.
Will post up pics soon.
Old Aug 7, 2014 | 06:39 AM
Mish_Mish's Avatar
Mish_Mish has much to be proud ofMish_Mish has much to be proud ofMish_Mish has much to be proud ofMish_Mish has much to be proud ofMish_Mish has much to be proud ofMish_Mish has much to be proud ofMish_Mish has much to be proud ofMish_Mish has much to be proud of
Coolant pipe fix
Expansion tank
Water pump
Clutch kit
Spark plugs
Water hoses
Fuel filter
Air filter
Crankshaft seal
Boost pressure test
Wastegate adjust
Endless brake fluid
Coolant
Throttle body seal
Transponder
Now this is what I was hoping for, thank you!!!
Old Aug 7, 2014 | 07:17 AM
agreed 100%!! i'm trying to determine which one i spend more on. but i keep keeping the car
..and as you know,.. there are startup costs with women
Old Aug 7, 2014 | 09:57 AM
996TWINS's Avatar
Items that I had done prior and you may what to do too:
Coil packs
Solenoid brackets
Engine mounts (RSS)
Timing belt
2nd gear detent
split71's Avatar
split71 has a reputation beyond reputesplit71 has a reputation beyond reputesplit71 has a reputation beyond reputesplit71 has a reputation beyond reputesplit71 has a reputation beyond reputesplit71 has a reputation beyond reputesplit71 has a reputation beyond reputesplit71 has a reputation beyond reputesplit71 has a reputation beyond reputesplit71 has a reputation beyond reputesplit71 has a reputation beyond repute
Nice list! What did it run you to have the pipes welded? I know you have a lot of other items done, but was the labor itemized for you?
Old Aug 7, 2014 | 10:06 AM
996TWINS's Avatar
I believe the coolant pipes were under $2K.
The BIG savings was in the labor. Many items my shop did not charge me for installation, since the parts were right there to be easily replaced with the engine out.
Old Aug 7, 2014 | 11:12 AM
re-reading it, that list is a very nice refresh. just wondering if given your track days etc if you have ever refreshed your gearbox. that has been both my tt's achilles heel so to speak
Old Aug 7, 2014 | 11:17 AM
996TWINS's Avatar
Not yet!
What happened to your gear boxes?
Old Aug 7, 2014 | 11:54 AM
Not yet!
not tryin to jinx ya
1st car had 2nd gear pop. current car needed bearings as it has seen its share of track days. thrust/pinion bearings + enough heat cycles = eventually.
