NEED HELP ASAP! 996 hood lock
Hey there, first post here
I need help.. my mate took the battery out of his 996 to charge it and left the hood a bit open due to the electrical lock..
But, a smartass that walked by and closed the hood..
What to do now?
we´d really apprechiate some help...
thx.
What to do now?
thx.
What year 996? Open the fuse panel and pull out the little red fuse-looking thing that has a pic of the car hood on it. Grab some jump cables and attached the red (+) to the red fuse-thing and the black (-) cable to the door jam and see if that will pop your hood open without the battery.
Behind the right headlight is an emergency cable. Pry the bottom of the headlight assembly upwards slightly using a paint stirrer or similar flat object. Then reach between the bumper and headlight assembly with a coat hanger (wrapped in tape to prevent scratching). You should be able to grab the loop at the end of the emergency cable and pull it out. Now pull the cable firmly and the hood will open.
The fender liner can also be removed (front part only if you would like) for access to the cable. When I replaced my front bumper I ran a line from the hood cable to the tow plug in case I need to access the hood in the absence of electical power.
and it worked instantly!
And my mate now owes me a pizza
Jul 29, 2019 11:13 AM
greekc6
Sep 16, 2015 02:49 PM
