Battery Warning Light
Old Apr 15, 2006 | 02:29 AM
vinnam's Avatar
vinnam is infamous around these parts
Unhappy Battery Warning Light
Hi guys,
On the way home, the battery warning light came on for my C4S... parked the car and switched off the engine... then starting her up again... but the warning light is kept staying on.
The manual says it might be caused by:
a. fault in the battery charging system; or
b. broken drive belt
I looked into the engine bay and can see the drive belt is still ok (i think).
Just wondering whether some of you guys had a similar problem before or not. this is the first time it came up...
Many thanks,
Vinnam.
Old Apr 15, 2006 | 09:04 AM
Miykl's Avatar
Miykl is infamous around these parts
use a multimeter across your batery terminals and get the voltage readings with the car running and off. Off should be ~12, running is typically in the 13-14 volt range (not sure on the Porsche, but's the range most charging systems run at. You should also check the terminals for corrosion and tightness.
DetomasoGTS74
Nov 11, 2015 09:01 AM
sypherdiaz
Aug 29, 2015 12:16 PM
GSR Autosport
Aug 26, 2015 05:20 PM
pwdrhound
Aug 23, 2015 07:36 PM
DSCOFF
Aug 23, 2015 01:22 PM
