Coolant smell... expansion tank already replaced
Old Apr 19, 2006 | 10:13 PM
itradem's Avatar
itradem is infamous around these parts
Guys,
I recently had my expansion tank and cap replaced due to a small crack that I didn't want to get any worse. However, I am still getting a coolant smell coming from behind the left side rear tire. There don't appear to be any leaks, and the system seems to be holding pressure very well... I removed the cap 5 hours after my morning commute and got a pronounced hiss, releasing the system pressure.
I might have a little bit of air left in the system after I had ALL of the coolant flushed, but would this cause a smell??? In any case, I will run it with the bleeder valve open tomorrow to purge any more air.
Any other likely culprits for this smell??? Could some spilled coolant still be burning off after 2 weeks of use since the tank replacement???
Old Apr 20, 2006 | 05:51 AM
Wagner996's Avatar
Wagner996 is infamous around these parts
I had my expansion tank changed out as well. Is it possible some excess coolant from the leak is still 'standing' somewhere in the car? What I did was take a hose and sprayed out the bottom of the car after I had the tank replaced to clean out and coolant the had puddled.
Old Apr 20, 2006 | 08:48 AM
teflon_jones's Avatar
teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !
If you don't see any fresh drips on the ground, it's probably just left over coolant from when it was replaced.
Old Apr 20, 2006 | 12:33 PM
itradem's Avatar
Thanks Guys!
audipwr1
Sep 25, 2021 01:31 PM
orbelo
Aug 30, 2015 12:26 PM
LiquidElephant
Aug 27, 2015 06:17 PM
Lucid Moment
Aug 20, 2015 02:22 PM
