Rear main seal oil leak.
Old Dec 19, 2003 | 08:59 AM
path's Avatar
path is infamous around these parts
Sorry to hear it Greyghost. Best of luck.
Pat
Old Dec 19, 2003 | 09:51 AM
RobynC's Avatar
Porsche Chick
RobynC is infamous around these partsRobynC is infamous around these parts
You had an RMS on your Turbo?
Originally posted by msindi
FYI - my clutch was replaced with RMS cause oil leaked onto my clutch
Wow, that is interesting. I thought they were immune to such things.
Old Dec 19, 2003 | 01:53 PM
nova996's Avatar
nova996 is infamous around these parts
Sorry to hear that. My 03 developed this problem before 1,000 miles!
Old Dec 19, 2003 | 02:14 PM
wakejudge's Avatar
wakejudge is infamous around these parts
Sorry to hear this Greyghost...
Is it the crank shaft oil seal that's gone, is that what's termed as main real seal ?
There has been mention of the early 996's - mine's a 99, but only with 11,000 miles on the clock so far and I have noticed any problems like this or other wise (fingers crossed - English saying for luck). When I brought it I was warned about the crank shaft oil seal and this was checked when buying the car 12 months ago - hence asking whether this is what you are referring to.
Old Dec 19, 2003 | 02:25 PM
Greyghost's Avatar
Greyghost is infamous around these parts
To my limited knowledge it is the seal between the engine and the flywheel at the transmission. Oil is slowly dripping from that joint.
Old Dec 19, 2003 | 04:12 PM
RobynC's Avatar
Porsche Chick
Crank (RMS) Seal Picture
The above picture if from my old Boxster. The tool for measuring the bore to ensure concentricity of your crank is inserted where the seal would actually go. And additionally, just below the RMS is the cover for the ISS. In this picture you can see it. Smaller diameter circle. The transmission slips right in here. The flywheel is bolted right the area around the crank, you can't see the holes because of the tool. Of course, this is on a Boxster, so things are backwards.
audipwr1
Sep 25, 2021 01:31 PM
Jul 29, 2019 11:13 AM
gulf gt
Aug 27, 2015 10:27 AM
The Oss
Aug 24, 2015 08:19 PM
Because_R4CEC4R
Aug 23, 2015 08:53 PM
