Convertible owners, need some help!
Old May 5, 2006 | 03:57 PM
Officer Cartman's Avatar
Officer Cartman is infamous around these parts
I replaced the battery, and shortly after that, I noticed that the passenger window wasn't going down when opening the door. I did the sequence to reset the automatic windows, thinking that was the problem. The window rolls up and down just fine, but when you open the door, the window doesn't move down that inch or so. You hear the motor make a noise, but no movement. If you push on the window with your hand, the window will move down - Which leads me to believe this isn't an electronics problem, but some mechanical problem that just coincidently happened during the battery swap.
Any ideas on where to start?
Old May 5, 2006 | 04:04 PM
djantlive's Avatar
Try cycling the top up and down a few times, followed by the window reset by pressing the window switch up and down. See if any change.
Old May 5, 2006 | 07:03 PM
Some others seem to think it's the window regulator that's shot.. Fun.
turbotuner20v
Sep 11, 2015 12:02 PM
Sales@RSW
Sep 3, 2015 09:34 AM
spreeon
Aug 27, 2015 08:14 PM
