Problem with the driver seat electrical adjustment
Old Sep 28, 2006 | 09:59 AM
Fredde08's Avatar
Fredde08 is infamous around these parts
My mate´s dad has a 996 carrera with a annoying problem
The Driver seat cant be adjusted in any way, when you press the buttons to move it, nothing happens, You hear that "bwww" noise as it would be moving but nothing happens..
The Porsche workshop has a 1 month waiting time so, it would be great if someone here knows what the problem is and how to fix it..
Thanks,
Fredde
Old Sep 28, 2006 | 10:13 AM
jaded996's Avatar
jaded996 has a spectacular aura aboutjaded996 has a spectacular aura aboutjaded996 has a spectacular aura about
Does it not try to move at all? This may sound crazy but i have heard of pennies or other change getting stuck in the rail jamming things up on other cars. I have not actually looked at the rail setup on the 996's but it might be worth unbolting it and checking if there are any obstructions.
The fact you hear the motor is what led me to think this way.
Old Sep 28, 2006 | 10:23 AM
Fredde08's Avatar
Yeah, but.. you cant move it in any direction..
if a penny were stuck in the rail you´d still be able to tilt the back of the seat, right?
Maybe some kind of eletrical? but the motor runs :S
Old Sep 28, 2006 | 10:39 AM
jaded996's Avatar
It could be something wedged in there????
Old Sep 28, 2006 | 11:04 AM
Fredde08's Avatar
hmm.. yeah it could be that.. my friend looked between the seat and didnt see something strange..
Probably its going to end with me lying under the car unbolting it and lifting it out to see if somethings wrong..
Old Sep 28, 2006 | 11:09 AM
jaded996's Avatar
Good luck and keep us updated.
Old Sep 28, 2006 | 07:20 PM
Dharn55's Avatar
Dharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud of
There are three or four motors for a full power seat. Each is connected to the seat base with a small plastic tube/housing that contains the drive mechanism. These are secured to the motor and to the seat base/track with metal plates. Sometimes these tubes/plates will crack/break and need to be replaced. On my buddies car one of the tubes broke at the end and the seat lost the function of that motor. If you remove the seat (four torque X bolts) you can lift the seat and see the motors and drives. You might want to check this out.
cnebrask
Oct 3, 2024 08:19 PM
Jul 29, 2019 11:13 AM
pshep138
Sep 1, 2015 09:45 AM
The Oss
Aug 24, 2015 08:19 PM
pwdrhound
Aug 23, 2015 07:36 PM
