Battery/Alternator Q for K2
Before I put my 996 up for the winter, the battery kept on dying (got stuck at a mall once). Anyway, I thought it was the battery but the place I bought it at says (after testing) that the battery is fine. Is there any way for me to be sure? Also, could it be the alternator and if so, how hard is that to install myself (or should I leave it for the mechanic)? Thanks
You can check the alternator by hooking up a voltage meter at the battery. The voltage should read about 13 to 13.7V. If not, you will need a new alternator. I would probably not attempt it, but if you are inclined enough you can do it. If not, I would only take it to the dealer.
Replacing the alternator is a peice of cake for anyone who is mechanocally inclined. It takes less than an hour (including sipping coffee) and is pretty straight forward. The only trick is that you must turn the alternator clockwise after removing the bolts to get it to clear the brackets.
However, if you have the correct voltage reading when the car is running, as noted above, your problem is something else, like the battery.
