Fuel tank, please help !
Old Feb 19, 2007 | 11:32 PM
Vadim's Avatar
Vadim is infamous around these parts
Hello to all. I am sorry ,i don't post photo first before I even ask question .Promise I will do this ,soon I get my car back. My question is : When shop was preforming some body work on my car ,2000 C2 ,they remove fuel tank .And after they out tank back , i can't pump fuel ,if I using fuel pump. Only if I slowly pour from spare canister. Even when I do this ,I can hear how tank start sucking air inside.Any idea were they screw up during installation ?
Thank you in advance.
Vadim
Old Feb 20, 2007 | 12:47 PM
Onetime's Avatar
Onetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant futureOnetime has a brilliant future
I would take it back to the shop and have them double check everything. If necessary demonstrate the problem for them. Hopefully they'll make it right.
Old Feb 20, 2007 | 01:01 PM
Vadim's Avatar
Thanks for replay ,car is already in shop ,and i already paid them money too But mechanic is idiot ..and if i can point him in right directions ( i am talking about my car ) ,so it will be really helpfull .I was thinking they bend somewere air hose during installation .Any ideas?
Thank you
Vadim
Old Feb 20, 2007 | 01:14 PM
Wheel Dynamics's Avatar
Wheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond repute
Possibly the hose was not attached to the tank properly or it's also possible that the pump and level seal wasn't sealed properly..... If the tank came out be sure to have the car aligned again. This means the sub-frame was removed.....
Good Luck,
-Eli
Old Feb 20, 2007 | 01:18 PM
Dr. T's Avatar
Dr. T is infamous around these parts
Vadim,
Check out this thread https://www.6speedonline.com/forums/...light=gas+tank
Maybe just a fuse.
Good luck.
Old Feb 20, 2007 | 01:21 PM
Vadim's Avatar
Thank you very much , i hope this is a was problem . Dr.T do you know any good trusted shops in our area ?
Vadim
Old Feb 20, 2007 | 01:36 PM
Dr. T's Avatar
I'm not familiar with any body shops but two good performance shops are Maxrpm in Bremerton http://www.maxrpmmotorsports.com/ and Fordahl in Bellevue http://www.fordahlmotorsports.com/.
Old Feb 20, 2007 | 01:43 PM
Vadim's Avatar
I went to Barrier Porsche once ..they suck
Thank you
Old Feb 21, 2007 | 12:48 PM
wyo996's Avatar
wyo996 is infamous around these parts
I had this happen when I had my SC serviced by Evo and found the answer on renntec forum. It was fuse E-6 I believe. It would blow again as soon as I replaced it until I taped over the cell phone connector behind the dash center console. A very easy fix but even Evo and my dealer did not know about this simple solution. Will
Old Feb 21, 2007 | 12:54 PM
Vadim's Avatar
Thanks WYO . were exactly this cell phone connector located ?
Old Feb 21, 2007 | 01:04 PM
wyo996's Avatar
If you take off the little panel by the accellerator pedal, it just pops off, you will see a 3 or 4 pin electrical connector that is just flopping around. I just put a piece of duct tape over it and never had another problem. Will
Old Feb 21, 2007 | 01:07 PM
Vadim's Avatar
Damn , sounds very simple Thank you ,I will try this tomorrow
Old Feb 22, 2007 | 02:50 PM
nanya's Avatar
nanya is infamous around these parts
I had the same problem
Went through all of the above (changed the blown fuse - kept blowing), and finally went to the dealer. They found stripped wires that controlled the vapor valve. The wires are hidden in the neck of the gas tank. They replaced them. Labor intensive proceedure to replace two wires.
Hopefully you do not have the same problem.
Old Feb 22, 2007 | 04:14 PM
Vadim's Avatar
Just check all fuse's in morning ...they all good I guess next step is removing tank ....
Old Feb 23, 2007 | 11:51 PM
You don't need to remove the tank, way too much work, trust me I know. You'll need to remove the sub-frame/suspension parts etc. etc.
You can pull off the right front tire and plastic fender liner to access the line which goes to the tank. You can also pull the battery out and under the tray liner you can access the fuel sender and level. I would pull out the battery first to see if they got things sealed first before pulling the tire off.
Good Luck,
-Eli
