Radar Detector Hard Wire issues
Old Jul 3, 2007 | 11:09 PM
Sharp's Avatar
Sharp has much to be proud ofSharp has much to be proud ofSharp has much to be proud ofSharp has much to be proud ofSharp has much to be proud ofSharp has much to be proud ofSharp has much to be proud ofSharp has much to be proud of
hi guys, i have a passport 8500 X50, i am attempting to hard wire it and decided to use the telephone plug that is behind the storage bin, like some mentioned, i hooked up the power cable to the switched red and green wire like mentioned in the write up and the ground to the brown wire from the telephone plug, i checked both the inline fuse on the detector and the fuse in the cars fuse box, both are good, but i still don't have any power to the radar detector....
this is the write up i used:
http://gallery.rennlist.com/gallery/albur30
any help would be apreciated!
thanks
Old Jul 4, 2007 | 07:25 PM
SQLB's Avatar
SQLB is infamous around these parts
I did mine over a year ago using the same Passport unit and I wired it to the power cable used by the lights on the overhead console. Took me about 30 minutes total.
Old Jul 4, 2007 | 07:38 PM
Sharp's Avatar
well i got it done, there ar ea few reasons it took longer then it was supposed to:
-first kirby has in his write up that the red and green is switched, that is not the case, it is the green and black that is switched.
-then the bloody smart cord that i got was messed, it was wired backwards, the ground was actually the live and the live wire that had the fuse inline was actually supposed to be a ground!!
figured this by testing the little pins on the end that looks like a telephone jack, and the live and ground were different (swaped)as compared to the cigerette lighter plug in....
so i had to do some cutting an splicing, but got it all done, and decided to keep the detector just above the dash, for better detection, and since mine is a targa, it does not fit abouve the rearview mirror!
thanks for the input !!
Shalil
Old Jul 4, 2007 | 11:01 PM
Itzkirb's Avatar
oops, did I get the colors backwards?
Old Jul 5, 2007 | 12:41 AM
Sharp's Avatar
Kirby, ya seems as tho the green and black is the switched one, and the green and red one is the unswitched one, i just assumed that it may be a diff in the years but i doubt it
Old Jul 5, 2007 | 07:42 AM
Itzkirb's Avatar
ok made the change
COBB Tuning
Jan 1, 2025 09:02 AM
007AMV8
Oct 19, 2015 09:55 PM
Goonie
Sep 13, 2015 02:26 PM
turbotuner20v
Sep 11, 2015 12:02 PM
carrera4slakem
Aug 20, 2015 11:36 PM
