Newbie question... oil?
Old Jul 15, 2007 | 03:16 PM
aagau's Avatar
aagau is infamous around these parts
Here is my story
Bought the car last year, 02 996 50 000 miles, seller telling me it was Mobil 1 5W40 in it.
Of course I could not verify that.
Anyway, It dropped about 1.5 quarts in 3000 miles. Oil had 6000 miles total on it, so oil was still in good condition.
I changed the oil this spring and put in Mobil 1 0W40, as recommended by Porsche in Toronto.
Guess what, 3000 miles later it dropped about 0.25 quarts, I did not even top it up yet as it was at top mark to beggin with.
There is also less incidents of smoke on cold start, even if I drove the car hard the last time, compared to last year.
Everything is so much better, I am starting to wonder if the previous oils was Mobil 1 at all.
As far as climate, well I am 400 miles North of Buffalo, so it probably does not compare with your climate.
Old Jul 15, 2007 | 05:44 PM
Ray S (Chicago)'s Avatar
Ray S (Chicago) has a spectacular aura aboutRay S (Chicago) has a spectacular aura aboutRay S (Chicago) has a spectacular aura about
Two steps
1) Choose an oil from this list
http://www.wrightune.co.uk/downloads/approved_oils.pdf
2) Put it in your car
Old Jul 15, 2007 | 07:54 PM
tshack's Avatar
tshack is infamous around these parts
Just for confirmation...Synthetic right??
Old Jul 16, 2007 | 01:48 AM
Ronny's Avatar
Ronny is infamous around these parts
Yes the 0w40 and 5w40 is synthetic.
The 10W40 that i topped off with was not, I believe. I'll be getting my oil changed this week.
Old Jul 16, 2007 | 06:07 AM
zdr2k's Avatar
zdr2k has much to be proud ofzdr2k has much to be proud ofzdr2k has much to be proud ofzdr2k has much to be proud ofzdr2k has much to be proud ofzdr2k has much to be proud ofzdr2k has much to be proud ofzdr2k has much to be proud ofzdr2k has much to be proud of
not recommended mixing syn and non-syn. should have that oil changed. again stick with mobil1.
Old Jul 16, 2007 | 06:25 AM
1999Porsche911's Avatar
1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future1999Porsche911 has a brilliant future
Mixing a conventional oil with synthetic is NOT a problem and your seals love it.
Old Jul 16, 2007 | 08:40 AM
zdr2k's Avatar
I usually agree with you but not in this case.
As the Porsche Technical Bulletin indicates “Only Hydrocracked or full Synthetic oils are approved by Porscheâ€.
Group II — Mineral oils with quality additive packages. Most of the conventional engine oils are Group II.
Group III — Hydrogenated (hydroisomerized) synthetic compounds commonly referred to as hydrowaxes or hydrocracked oil. This is the lowest-cost of synthetic engine oils. Castrol Syntec is a Group III oil.
Group IV — Synthetic oils made from mineral oil and monomolecular oil called polyalpholefin or POA. Mobil 1 is an example of a Group IV synthetic oil.
All synthetic engine oils perform better than Group II (mineral) oils especially when tested according to the Noack Volatility Test ASTM D-5800.
The major advantage of using synthetic engine oil is in its ability to remain fluid at very low temperatures. This characteristic of synthetic oil makes it popular in colder climates where cold-engine cranking is important. This is even more critical in Porsche engines because of the close bearing tolerances.
If I was in your situation, I wouldn’t mix. Mobil1 is all I use. Of course, in an emergency conventional oil could be used short-term.
My 2 cents worth.
Old Jul 16, 2007 | 09:19 AM
As the Porsche Technical Bulletin indicates “Only Hydrocracked or full Synthetic oils are approved by Porsche”.
My 2 cents worth.
There is a big assumption you are making.....which is that Porsche is stating what is best for the car without ANY consideration for EPA and other regulartory requirements. You only need to review the hundreds and hundreds of TSB's they have issued (and continue to issue) to see that they regularly make mistakes in both engineering and recommendations.
If your accept the assumption that Porsche knows what is best for performance and longevity of the car, then you have no alternative but to follow their advice, regardless of how many times they change it. However, as an idividuals, we are not regulated by EPA requirements, emmision control, etc, and are free to actually choose what best protects our car.
BTW: Porsche also states that you do not need to change your oil for 15,000-20,000 miles. Who in the right mind would wait that long for any car they cared about? I guess we can also assume that Porsche windshield fluid and antifreeze are the world's best and that it is unsafe to drive on any tires other than "N" rated ones?
All this expert advice from a company who brags that it is ok to burn through 10 quarts of oil every 6000 mles.
Old Jul 16, 2007 | 11:02 AM
zdr2k's Avatar
ok......to each his/her own.
Porsche designed and built the damn thing......you'd think they'd know, eh?
Old Jul 16, 2007 | 11:11 AM
UCrazyKid's Avatar
UCrazyKid is infamous around these partsUCrazyKid is infamous around these parts
Ronny,
Still keep an eye on things and check under the car for leaks. RMS seals can fail multiple times. Mine has been changed twice. It could also be the intermediate shaft bearing. A more serious problem if it is leaking.
When you have your oil changed have them visually check the motor for leaks.
Welcome aboard.
Old Jul 16, 2007 | 04:39 PM
slaaw's Avatar
slaaw is infamous around these parts
Originally Posted by Ronny
I've had my car for 3 weeks / 2000 miles and it's eaten up quite a lot of oil.
What constitutes "eaten up quite a lot of oil"? Mine uses about 0.5 qt in 6k miles.
Old Jul 16, 2007 | 11:17 PM
phaphaphooey's Avatar
phaphaphooey has a reputation beyond reputephaphaphooey has a reputation beyond reputephaphaphooey has a reputation beyond reputephaphaphooey has a reputation beyond reputephaphaphooey has a reputation beyond reputephaphaphooey has a reputation beyond reputephaphaphooey has a reputation beyond reputephaphaphooey has a reputation beyond reputephaphaphooey has a reputation beyond reputephaphaphooey has a reputation beyond reputephaphaphooey has a reputation beyond repute
Originally Posted by Ray S (Chicago)
Two steps
that list is a few years old. i believe the updated list is slightly different but i have yet to find a reliable website that houses it.
Old Jul 17, 2007 | 09:27 AM
HeelToeAndGo's Avatar
HeelToeAndGo is infamous around these parts
mobile One always, if not at walmart online
I've had my car for 3 weeks / 2000 miles and it's eaten up quite a lot of oil. What brand of oil is recommended that I can find at walmart?
Also, I have no idea whether the oil used before was synthetic or not. Are there any consequences in mixing the two?
ECS Tuning - BMW
Sep 22, 2015 08:34 AM
ECS Tuning - BMW
Sep 22, 2015 08:00 AM
ECS Tuning - BMW
Sep 22, 2015 07:49 AM
ECS Tuning - BMW
Sep 22, 2015 07:31 AM
andbos
New Member Introductions
Sep 10, 2015 10:43 AM
