Brake fade question
Old 04-26-2004, 08:49 AM
SANDOVAL's Avatar
Banned by Moderators
SANDOVAL has a spectacular aura aboutSANDOVAL has a spectacular aura aboutSANDOVAL has a spectacular aura about
Brake fade question
Since the day I bought my car it has always had a weird braking quirk. I posted about it a while back. I thought I would post again since I should probably take the car in. When ever I am braking and I hit a bump in the road the brakes feel like they give and let go, it is a very strange feeling. The only thing I can compare it to is brake fade.
Today coming into work I was following an AS C4S ( BTW Great looking car if you are on here) when I was coming off of a big sweeping offramp ( Ave. of the arts and I5 ) I was doing prob 85 and then braking as there is a light at the end of the offramp. The brakes felt real jerky, it was a very uneasy feeling.
So what do you guys think? Warped rotors? Bad bleed job? ABS acting up? or ???
I am puzzled what ever it is I am going to take the car in.
Old 04-26-2004, 09:21 AM
eride996's Avatar
eride996 is on a distinguished road
eric,
i have had the same incidents, but it was over stutter bumps or gravel. if it was a smooth surface i would believe it was the abs and maybe a combination of bubbles in your brake line. especially if you have had your calipers removed at one point.
Old 04-26-2004, 10:26 AM
SorTurbo's Avatar
SorTurbo is on a distinguished road
Wouldn't the bumps in the road cause 1 or more of the wheels to lose traction momentarily (airborne?) and thus cause the PSM to interfere with braking etc? not sure though
Old 04-26-2004, 10:30 AM
Itzkirb's Avatar
Same thing here...Braking over speedbumps cause it to shudder or something?
BTW, I don't have PSM so that can't be it.
Old 04-26-2004, 10:32 AM
RobynC's Avatar
Porsche Chick
RobynC will become famous soon enoughRobynC will become famous soon enough
Eric -
It's hard to describe...but does it almost feel like you are going over rocks when braking? A metallic pulse?
Old 04-26-2004, 10:33 AM
SANDOVAL's Avatar
Same thing here meaning you have the same problem? or you are thinking it is PSM? I will shut PSM off tonight... but that still does not explain the shudder problem that I experienced while braking around the sweeping off ramp.
Old 04-26-2004, 10:36 AM
SANDOVAL's Avatar
I don't know how else to descibe it other then it is kinf of like brake fade like you are driving a big truck coming down a big hill. But then it will be fine and the brakes will stop fast and hard like they should.
Old 04-26-2004, 10:40 AM
Itzkirb's Avatar
Robyn, mine is like you describe. Oh no, do i have a Robyn Issue?
Old 04-26-2004, 10:45 AM
RobynC's Avatar
Porsche Chick
If it's anything like what I described, I questioned this sensation when I had my Boxster. And that is what ABS feels like in our cars. It is perfectly normal. Every Porsche I have ever driven (So many loaner Boxsters...ug!) has felt this way and it's just a characteristic of the ABS of these cars. (As I have been told by two different mechanics...)
Isn't fade when you can push the pedal to the floor and nothing is happening?
Old 04-26-2004, 01:56 PM
TT Gasman's Avatar
TT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant future
Brake shudder is typically caused by excessive pad material embedded onto the rotor. This usually happens when the brakes are applied on hot rotors, such as in the pits after a run session, a small amount of material gets left on the rotor and you get shudder. I had this occur on the C2 I drove at PDE, by the end of the day it was fine.
The infamous warped rotors would also behave this way, although there is some debate as to wether this is a true phenomenon.
Old 04-26-2004, 05:39 PM
Turbo Ron's Avatar
Turbo Ron is a name known to allTurbo Ron is a name known to allTurbo Ron is a name known to allTurbo Ron is a name known to allTurbo Ron is a name known to allTurbo Ron is a name known to all
Normal Abs feel bracking over small bumps on the road.
Old 04-26-2004, 06:20 PM
RobynC's Avatar
Porsche Chick
Exactly!! So hard to describe yet you did it perfectly in so few words! Thanks!!
Old 04-28-2004, 03:52 AM
Jenner's Avatar
Jenner has much to be proud ofJenner has much to be proud ofJenner has much to be proud ofJenner has much to be proud ofJenner has much to be proud ofJenner has much to be proud ofJenner has much to be proud ofJenner has much to be proud of
Correct. SANDOVAL is using the wrong term to describe what he is feeling.
In the case of fade, more and more pedal travel is required to stop, and the pedal becomes soft and spongy feeling.
The feeling SANDOVAL describes, is during braking on uneven or rough roads, the brakes on one or both of the front wheels feel like they stop working for a split second or two, BUT the pedal travel and firmness remains the same, and braking resumes as normal a second later. It may be that ABS is kicking in so fast and for such a short time, that there are no "pulses" in the pedal to communicate to the driver that ABS is active.
I experience this too in my 2003 911. It was a bit unsettling at first, but I am sure it is just part of the ABS system on these cars.
04-28-2022 12:38 AM
COBB Tuning
01-29-2022 09:42 AM
Sales@RSW
09-03-2015 09:34 AM
ECS Tuning - VW
08-20-2015 03:07 PM
Quick Reply: Brake fade question
