Bumper Installation Help
Old Aug 17, 2007 | 11:50 AM
PTarga's Avatar
PTarga is infamous around these parts
Question Bumper Installation Help
Putting a Turbo front bumper on my car. Can someone please give some instruction?
Thanks all....
Old Aug 17, 2007 | 12:38 PM
p0rsch3's Avatar
p0rsch3 has a reputation beyond reputep0rsch3 has a reputation beyond reputep0rsch3 has a reputation beyond reputep0rsch3 has a reputation beyond reputep0rsch3 has a reputation beyond reputep0rsch3 has a reputation beyond reputep0rsch3 has a reputation beyond reputep0rsch3 has a reputation beyond reputep0rsch3 has a reputation beyond reputep0rsch3 has a reputation beyond reputep0rsch3 has a reputation beyond repute
did you try the DIY forums on renntech.org?
Old Aug 17, 2007 | 12:39 PM
nine9six's Avatar
nine9six is infamous around these partsnine9six is infamous around these parts
2 screws on top, one behind each sidemarkers, on under the side marker behind the well liner, and about 6 screws on the bottom.
From doing my conversion, the stock aluminum bumper behind the bumper cover will need to be trimmed on both side or the grills will not fit.
Old Aug 17, 2007 | 01:09 PM
CosmosC4S's Avatar
CosmosC4S is a jewel in the roughCosmosC4S is a jewel in the roughCosmosC4S is a jewel in the roughCosmosC4S is a jewel in the rough
Removing the Front Bumper Cover
1. Remove the center cover (3) from the inside of the front trunk.
Turn the 4 hexagon cap nuts (2) by 90° and remove cover upwards and off.
Undo the 2 sheetmetal screws (4) from the top.
2. Remove the sidemarker light (5).
Gently pry off sidemarker light (A) at the sides with a flat-head
screwdriver and pull out the sidemarker light (5),
disconnect electrical plug connection (by squeezing the metal clip to release it).
3. Remove the screws (6) and (8), careful not to lose spacer sleeves (7) and screw clip (9).
To get to screw (6), you will need to remove the wheel liner partially.
Remove the plastic rivet on the wheel liner (near the sidemarker),
and remove 3 or more screws, as required, to get your hands inside and behind the wheel liner.
4. Remove the temperature sender probe.
Press temperature sensor (10) out of the air-inlet grille.
You can either disconnect the electrical connection and set it aside or leave it attached.
5. Remove all the screws (12) from the bottom side of the bumper cover.
There are a total of 15 screws holding the bumper cover on the bottom
(not counting the screws on the inside of the wheel liner).
The 2 plastic rivets (11), one on each side of the bottom edge,
hold the plastic covers that are integral parts of the wheel liners.
Removing them is optional, you can also leave them hanging if the wheel liners are not completely removed.
Remove the bumper cover by lifting slightly and pulling it off to the front towards you.
Old Aug 17, 2007 | 02:01 PM
p0rsch3's Avatar
Nice post Cosmos
Old Aug 17, 2007 | 05:53 PM
PTarga's Avatar
I love this board. Thanks so much everyone!
Mackchacha
Jul 9, 2019 11:03 AM
Sep 14, 2015 06:42 PM
Nissan GTR
Aug 19, 2015 02:11 PM
Lifeisgood2
Aug 19, 2015 10:02 AM
