My Xenons keep turning off. will work on them this weekend.
Old Aug 30, 2007 | 05:11 PM
yellowbmr's Avatar
yellowbmr is just really niceyellowbmr is just really niceyellowbmr is just really niceyellowbmr is just really niceyellowbmr is just really nice
is there anything you can suggest to help me find the darn problem. It's intermittent, mostly when i go over bumps the light turns off (passenger and sometimes driveR). then i turn off the light switch and back on. and it works again. sometimes at night i drive without noticing which side is off since i have my fogs on also.
Is it the connector part that goes bad?
thanks.
Old Aug 30, 2007 | 05:21 PM
Jimbo's Avatar
Jimbo has much to be proud ofJimbo has much to be proud ofJimbo has much to be proud ofJimbo has much to be proud ofJimbo has much to be proud ofJimbo has much to be proud ofJimbo has much to be proud ofJimbo has much to be proud ofJimbo has much to be proud ofJimbo has much to be proud of
Typically the bulbs don't go bad... 85% of the time, the ignitors (or ignitor modules, whichever you want to call it) go bad.
Old Aug 30, 2007 | 05:25 PM
yellowbmr's Avatar
you mean the ballasts?
last time i was here, someone mentioned the connectors are bad.
Now it's the ballast?
Old Sep 4, 2007 | 08:04 AM
wdonovan's Avatar
wdonovan is infamous around these parts
Have you checked that the light assemblies are properly seated in the fenders? Sounds like they're shaking around. Happened to me when one was removed and replaced. I don't see an ignitor failing intermittently like that. Nor a bulb.
Old Sep 4, 2007 | 11:29 AM
daytrader's Avatar
daytrader is infamous around these parts
Yellowbmr,
I had the same problem last year. I took mine to a local Porsche shop. Found out that my headlight switch was worn out and faulty. Replace the switch and took care of the problem.
cadman
Nov 13, 2025 08:57 AM
cinellipro
Dec 20, 2017 07:12 PM
jyupitt1
Sep 23, 2015 06:26 AM
pshep138
Sep 1, 2015 09:45 AM
DSCOFF
Aug 23, 2015 01:22 PM
