tiny mod - endurance foglights
Old Oct 15, 2007 | 03:30 AM
haudimal's Avatar
haudimal is infamous around these parts
Originally Posted by atomic80
I took my Hoen Xenonmatch bulbs out after finding out that they burn 15 degrees hotter than stock. The Hoen parking light bulbs melted my turn signal housing. I'm not sure if the foglight housing is able to handle the increased heat either. Did you find out if those Endurance bulbs burn any hotter than stock? I'd keep a close eye on these if I were you.
I wrote the problems in your threads and because of that i didn´t changed the parking light bulbs and with the LEDs i got a warning.
But the lenses of the foglights are made of glas and not plastic, so i hope they are more restistant - but i will have a look.
Did you notice, that the stock parking light bulbs are philips blue vision already and they should have a 3400k light, that matches the xenon better than normal bulbs?
Old Oct 15, 2007 | 08:08 AM
gradyex's Avatar
gradyex is infamous around these partsgradyex is infamous around these parts
They should just twist off Chris. You must have a bad seal or something. There should be no condensation? If both are affected that would seem odd. Have the dealer check them out (under warranty). haudimal, your correct they are a PITA to change unless you have hands the size of a 5 year old! I did it after cussing and fussing for God knows how long. You need to jack the front end up to do it (better on a lift) or remove the entire front bumper which is not absolutely necessary.
Old Oct 15, 2007 | 08:25 AM
TT Surgeon's Avatar
You know I had to drive thru a heavy downpour when I first got the car, never went away.
Old Oct 15, 2007 | 09:00 AM
atomic80's Avatar
haudimal, great idea! I'll check into seeing if I can get those 3400k bulbs and I'll double check to make sure that they don't burn 15 degrees hotter than stock.
It took me a VERY long time getting those foglight bulbs changed. I finally gave up on one and took it to my dealership. They were happy to finish the job for me. It took the technician exactly 2.5 minutes to make the swap!
Old Oct 15, 2007 | 09:22 AM
gmoney's Avatar
Stock TT bulbs are indeed blue tinted from the factory, but they dont match low beams at all.
carwash
16
Oct 9, 2018 07:22 PM
ggf
Sep 17, 2015 11:40 AM
ECS Tuning - VW
Sep 9, 2015 12:01 PM
