tiny mod - endurance foglights
Old Oct 12, 2007 | 05:35 PM
haudimal's Avatar
haudimal is infamous around these parts
changed the stock foglights to the hoen endurance foglight. Driving around with foglights on is not my business, but the xenon is so close to daylight in the mirrors, that you are happy to get a little bit more attraction when you are rushing on the autobahn by day. You will not believe what kind of blind ****** you can find over there.
Old Oct 12, 2007 | 05:55 PM
Paris_CarreraS's Avatar
Paris_CarreraS is a jewel in the roughParis_CarreraS is a jewel in the roughParis_CarreraS is a jewel in the rough
they look yellow!
Old Oct 12, 2007 | 05:58 PM
eurospek's Avatar
eurospek is infamous around these parts
Originally Posted by Paris_CarreraS
they look yellow!
Hoen Endurance are yellow!!! I too rock yellow fogs with my xenon lights, looks hot IMO.
Old Oct 12, 2007 | 06:24 PM
AsianImage's Avatar
AsianImage is a jewel in the roughAsianImage is a jewel in the roughAsianImage is a jewel in the rough
by definition "fog" lights are supposed to be yellow. yellow cuts through the "fog" much better than "White" light.
Old Oct 13, 2007 | 05:13 PM
gmoney's Avatar
Very Euro, perfect for the TT and functional to boot. Nice.
Old Oct 13, 2007 | 05:41 PM
MKS's Avatar
MKS
MKS is a glorious beacon of lightMKS is a glorious beacon of lightMKS is a glorious beacon of lightMKS is a glorious beacon of lightMKS is a glorious beacon of light
Different! i should try them on my red turbo for a change!
Old Oct 13, 2007 | 05:42 PM
MKS's Avatar
MKS
Whats the bulb size? is it H3?
Old Oct 13, 2007 | 06:59 PM
WARDHOG's Avatar
WARDHOG is infamous around these parts
Try these. I have had them for over four years and are still brite and even colored.
http://www.brandsport.com/piaa-13555.html
Old Oct 13, 2007 | 08:15 PM
atomic80's Avatar
I took my Hoen Xenonmatch bulbs out after finding out that they burn 15 degrees hotter than stock. The Hoen parking light bulbs melted my turn signal housing. I'm not sure if the foglight housing is able to handle the increased heat either. Did you find out if those Endurance bulbs burn any hotter than stock? I'd keep a close eye on these if I were you.
Old Oct 14, 2007 | 01:45 PM
gmoney's Avatar
Only the W5W city light burns 15 degrees hotter than stock, the xenonmatch oem wattage and endurance and also all weather generate same as stock bulb surface temps.
The difference is the W5W glass is not coated but the glass itself is dark blue which increases heat retention. The W5W is also hard glass vs. UV cut on the fog lights which adds to heat retention.
I've been running the fog lamps in various cars for years, no problem.
Old Oct 14, 2007 | 02:10 PM
atomic80's Avatar
I'm sure that the foglights are fine, I just didn't really want to risk it with these Hoen bulbs. The C5W license plate bulbs are also the same as the W5W bulbs as well. I removed those too.
Old Oct 14, 2007 | 08:14 PM
TT Surgeon's Avatar
How do you get those fog lights out? Can't figure it out.
Old Oct 14, 2007 | 09:26 PM
atomic80's Avatar
It wasn't easy, that's for sure. You have to put the car on a lift or at least raise it off the ground, take the outer cap off and then twist/pull the inner socket out. Be SURE to get the wiring/harness back in exactly the same way too. Reverse the procedure. It's MUCH easier with the car on a lift.
Old Oct 14, 2007 | 10:29 PM
TT Surgeon's Avatar
I just need to get the outer cap off, I've got a **** load of condensation in there.
Old Oct 15, 2007 | 03:20 AM
haudimal's Avatar
But be shure to have your 8 year old daughter doing the job;-) You need really small hands - my hands look as if would have fight a crazy cat.
