Realignment again
Old Nov 4, 2007 | 07:39 AM
bbywu's Avatar
Realignment again
After a great summer of driving, I hear snow is on the way to Wisconsin. I'm planning on a few things to service...including redoing the alignment after driving the crappy roads in the area.
Any comments about the following specs?
Front:
camber -0.9
all else stock configuration range
Rear:
camber -1.9
toe 0 (a little out of range)
Any comments?
Old Nov 4, 2007 | 08:33 AM
eclou's Avatar
eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !
-1.9 on the rear is going to wear the insides of the tires very quickly. I run -1.6 and already am down to the wear bars on the inner blocks with 5/32 left on the outers
Old Nov 4, 2007 | 10:15 AM
bbywu's Avatar
Thanks. I was hoping you'd reply. The advice you gave on your previous posts regarding your alignment and springs was really helpful.
If I back off on the camber, will leaving the toe on the rears near 0/neutral help with the squirrely feeling when I accelerate through corners?
Old Nov 4, 2007 | 01:16 PM
eclou's Avatar
I was told we still need about 16 minutes of positive toe (out) per side in the rear. Dynamically under acceleration, the rear wheels will try to toe-in, and if you start with static zero toe under accel you will actually be toe-in
Old Mar 6, 2008 | 02:14 AM
Tanders's Avatar
Tanders is infamous around these parts
Hi! Does anyone here have the original Porsche (OEM) wheel alignment specs for the 997 turbo?
Thanks!
996_911C2_Dhru
May 21, 2015 03:09 PM
overzealous1
Apr 10, 2015 04:51 PM
canberk
Cayenne 955/957
Oct 16, 2009 03:40 PM
samlad
Nov 25, 2008 08:31 PM
