Upgrading my 997 Turbo to 750-800 HP!
Old 03-02-2008 | 05:01 PM
Originally Posted by keithta
Another problem that I found that was affecting my drag strip results as well as the overall performance of my car were the Blow Off Valves!
....The springs inside the Blow Off Valves Im using are too soft! They are causing me to blow off 100% of my boost pressure between shifts.
Just so you know some tried running without BOVS... so ur on boost all the time... VERY dangerous...
... if you want better results you need a 17 inch rear rim with 275/40/17 MTs.... and have the ***** to shift the car faster... (speed shift)....
I don't think it has anything to do with ur BOVs( assuming they are not stock). I have another car and the boost drops to 0 between shifts as well.... just like in my P car... thats just the way these things are...
Bobby, Todd's friend, ran a 997 just on a flash at 15 psi at 11.2 @ 127 mph... all stock except 17 tires, an ecu at 15 psi and a hell of a good driver...
markski
here is a bad launch:
http://www.youtube.com/watch?v=DSGNiG0MTJA
and here is a better one...
look at the end of the video...
http://www.youtube.com/watch?v=jLSysligeF8
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
  #122
Old 03-05-2008 | 12:07 AM
Nthusiastt's Avatar
Nthusiastt is a splendid one to beholdNthusiastt is a splendid one to beholdNthusiastt is a splendid one to beholdNthusiastt is a splendid one to beholdNthusiastt is a splendid one to beholdNthusiastt is a splendid one to beholdNthusiastt is a splendid one to behold
You want to bleed out all of the pressure in the charge pipes in between shifts.
My understanding is you want to keep the turbine speed as high as possible. When the charge pipes contain pressure and the throttle plates are closed you get compressor surge which reduces turbine speed. The charge pressure of the pipe doesn't matter when your off throttle because your turbine speed will be so far reduced by the back pressure when you do get on the throttle again you'll have to re-spool. Remember, it's all about turbine speed, not pressure when your off throttle.
  #123
Old 03-05-2008 | 12:13 AM
Mastermind's Avatar
Mastermind is infamous around these parts
WOW 10 Seconds in the 1/4 mile is a really nice feeling......good luck to ya!
  #124
Old 06-16-2008 | 11:58 PM
Alex's Avatar
Alex has a brilliant futureAlex has a brilliant futureAlex has a brilliant futureAlex has a brilliant futureAlex has a brilliant futureAlex has a brilliant futureAlex has a brilliant futureAlex has a brilliant futureAlex has a brilliant futureAlex has a brilliant futureAlex has a brilliant future
Great results there, Keith. Congrats on pushing the limits successfully.
  #125
Old 06-18-2008 | 02:01 AM
stevebez's Avatar
stevebez is infamous around these parts
Very interesting write up and congrats Keith.
How much power did the IPD plenum add in the end?
How about a 40-140 MPH run thats where this car should be a complete animal....? I personally dont care much for drag racing but more for running from a roll...
Smaller rims and fatter profile tyres should help the wheel hop... maybe the sharp clutch you have is not ideal for massive launches either. Beef up half shafts and you should be able to be more adventurous... !!!
  #126
Old 06-18-2008 | 03:22 PM
KingMotor's Avatar
KingMotor is infamous around these parts
good luck!!! if money is not a problem you will reach your goal pretty soon!
  #127
Old 06-18-2008 | 04:35 PM
MJS NYC's Avatar
MJS NYC is infamous around these parts
Could be one of the better projects i've seen as of late, well done... just one question, when can we expect some high-res videos??
  #128
Old 06-19-2008 | 02:02 PM
997 GT3 RS/TT's Avatar
997 GT3 RS/TT has a reputation beyond repute997 GT3 RS/TT has a reputation beyond repute997 GT3 RS/TT has a reputation beyond repute997 GT3 RS/TT has a reputation beyond repute997 GT3 RS/TT has a reputation beyond repute997 GT3 RS/TT has a reputation beyond repute997 GT3 RS/TT has a reputation beyond repute997 GT3 RS/TT has a reputation beyond repute997 GT3 RS/TT has a reputation beyond repute997 GT3 RS/TT has a reputation beyond repute997 GT3 RS/TT has a reputation beyond repute
Hi,
what is your acceleration time from:
0-100km/h
0-200km/h
and 0-300km/h.
BTW
Your connecting rods can be broken all the time during hard acceleration.
All know that there the same from 993 N/A engine till now.
One more thing, pistons will last for about 30-40 hours, this is a problem of engines over 750 European ps.
There is a very long list of problems, gearbox, drive shafts......
Good luck,
Karol
  #129
Old 06-19-2008 | 10:59 PM
keithta's Avatar
keithta Is a GOD !keithta Is a GOD !keithta Is a GOD !keithta Is a GOD !keithta Is a GOD !keithta Is a GOD !keithta Is a GOD !keithta Is a GOD !keithta Is a GOD !keithta Is a GOD !keithta Is a GOD !
My car is running the stock plenum. Never put the IPD one in. : (
If you havent seen it yet, I ran a stock ZO6 here from rolling start.....45-160 mph. I let off around 180. Vette stops at 160.
http://www.youtube.com/watch?v=PRvrOMgau4k
  #130
Old 06-29-2008 | 06:54 PM
dk996tt's Avatar
dk996tt has much to be proud ofdk996tt has much to be proud ofdk996tt has much to be proud ofdk996tt has much to be proud ofdk996tt has much to be proud ofdk996tt has much to be proud ofdk996tt has much to be proud ofdk996tt has much to be proud ofdk996tt has much to be proud of
wow. impressive. did you have a chance to take your car to the drag strip yet?
  #131
Old 06-30-2008 | 01:21 AM
robertp's Avatar
robertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud of
The HP is easy to obtain and most of the tuners can get you there. I am wondering which clutch LWFW setup you have.
  #132
Old 06-30-2008 | 01:37 AM
Barrister's Avatar
Barrister is a splendid one to beholdBarrister is a splendid one to beholdBarrister is a splendid one to beholdBarrister is a splendid one to beholdBarrister is a splendid one to beholdBarrister is a splendid one to behold
I like the Sachs Stage II with the lightweight flywheel! That is what I have my eye on for when I finally run my stock clutch outta town!
Mackchacha
07-09-2019 11:03 AM
PelicanParts.com
997 Turbo Vendor Classifieds
08-20-2015 02:38 PM
PelicanParts.com
GT3/GT2/GT Vendor Classifieds
08-20-2015 02:37 PM
PelicanParts.com
08-18-2015 03:42 PM
PelicanParts.com
08-18-2015 03:41 PM
Quick Reply: Upgrading my 997 Turbo to 750-800 HP!
