IPD plenum is installed!
Old Feb 27, 2008 | 09:29 PM
atomic80's Avatar
Here are a few pictures of the IPD plenum pre-install
Cast metal
Looking inside, painted and designed with efficient airflow in mind
Compare that with the OEM plastic plenum
Not designed for airflow efficiency
The view of the inside from the top
Close up of my engine compartment with the OEM plenum removed
Engine compartment without OEM plenum
New IPD pleum in place. Notice that the cast metal matches the intake manifold too
Another view of IPD plenum
It took Cantrell Motorsport about 2.5 hours to install the plenum which should be pretty standard for tuner shops everywhere if they know what they're doing.
My initial impressions although done before the ECU has had a chance to relearn the new parameters of the airflow efficiency brought on by the new plenum from IPD/RSS is very good. From a standstill, there's a noticable reduction in turbo lag when moving from a standstill. The engine seems to be slightly more eager to get up to speed. Bottom line is, I'm very happy with this modification and will definitely recommend anyone considering this mod to go ahead and get it. I have no plans to do a dyno at this time since I didn't have a chance to do a pre-dyno test. I should be able to compare stock vs modified soon if Larry gives me the opportunity to do so. I'll give a final report after the ECU has had a chance to adapt.
Old Feb 27, 2008 | 10:10 PM
whyb2nd's Avatar
whyb2nd is infamous around these parts
excellent, look forward to your comments after ecu relearn.
Old Feb 27, 2008 | 10:30 PM
ALPINE_997's Avatar
ALPINE_997 is a splendid one to beholdALPINE_997 is a splendid one to beholdALPINE_997 is a splendid one to beholdALPINE_997 is a splendid one to beholdALPINE_997 is a splendid one to beholdALPINE_997 is a splendid one to beholdALPINE_997 is a splendid one to behold
Awesome Jason. The piece looks very well built. I have been waiting for your post. I hope to read more about it as it learns. I am sure that you will give us an honest opinion of what you feel.
Old Feb 27, 2008 | 10:35 PM
atomic80's Avatar
Count on it...my honest and unbiased opinion.
Old Feb 28, 2008 | 12:34 AM
TurboBill's Avatar
TurboBill is infamous around these parts
Jason, continuing on the topic we discussed on the other board, I am really interested in getting your impression of the Plenum over the next 100 or so miles. Your initial, out of the box, experience is the exact same as mine was, but I am very curious about the concept of the ECU taking serious time to "learn" the new mod.
Old Feb 28, 2008 | 12:54 AM
atomic80's Avatar
Bill, count on it, once I've had a chance to drive the Turbo a bit more. I'm glad to see that we're both on the right track.
Old Feb 28, 2008 | 11:41 AM
RSSGREG's Avatar
RSSGREG has a reputation beyond reputeRSSGREG has a reputation beyond reputeRSSGREG has a reputation beyond reputeRSSGREG has a reputation beyond reputeRSSGREG has a reputation beyond reputeRSSGREG has a reputation beyond reputeRSSGREG has a reputation beyond reputeRSSGREG has a reputation beyond reputeRSSGREG has a reputation beyond reputeRSSGREG has a reputation beyond reputeRSSGREG has a reputation beyond repute
IPD Feedback
Greetings 6 Speeders,
Jason, thanks for such a comprehensive thread. It's always nice to see customers delivering on their word that they will put up a "constructive" post. I'm glad to hear that your initial impressions are positive. We've sold over 65 997 Turbo plenums to date and we have had nothing but rave reviews thus far. Unlike the 996 Turbo, which adapts immediately, the 997 Turbo requires almost 50 miles to fully and completely adapt. It also appears that cars with additional mods are realizing greater horsepower gains than stock Turbos.
We just received the dyno chart below from a customer with a EVT 700 Big Power Kit. It also demonstrates how effective the plenum can be with extensive modifications.
Jason, thanks again for all your contributions and taking the time to post this thread. It's always a pleasure working together with customers like yourself.
Cheers,
Greg
Old Feb 28, 2008 | 07:30 PM
yrralis1's Avatar
Looks great and thanks for posting the pics. I have some questions :
1) Engine space looks tight with my Werks1 . Can this fit ?
2) Atomic (Jason) --Is your ECU "stocK". Also if not is re flashing necessary ?
3) Labor hours were presented in your post . Cost of the part (approx) ?
4) Did you add intercoolers ? What type of intake are you running with it? I have the Evo intercoolers on mine .
Thanks in advance
Old Feb 28, 2008 | 07:51 PM
atomic80's Avatar
I'm not sure if the plenum will fit with your Werks1 intake but it's pretty far within the engine compartment so it should. Yes, my ECU is stock. I'm still waiting for a good solution to come out. REVO, GIAC, Protomotive, etc. I want to go with a setup that has been optimized to use the plenum. Perhaps Greg could chime in on that. I'll let Greg answer the pricing question too. And finally, no, I'm not running any aftermarket intercoolers nor intakes.
Old Feb 29, 2008 | 10:03 AM
toffeGT2's Avatar
toffeGT2 is infamous around these parts
Thanks for the write up.... I am seriously consider getting one now.
Old Feb 29, 2008 | 11:19 AM
DSUNNYM1's Avatar
DSUNNYM1 is infamous around these parts
Will this part void any warranty??
Old Feb 29, 2008 | 12:26 PM
jonathan@millaracing's Avatar
jonathan@millaracing is infamous around these parts
Jason
looks great.
The IPD intake plenums are big sellers because they are simple and very effective
Old Feb 29, 2008 | 12:31 PM
gmoney's Avatar
As with any aftermarket part the dealer may see this as an excuse to give you all kinds of grief for issues that may, despite how remote they may seem, be related to the installation of this part.
I would think the chances of anything happening are highly unlikely.
Old Feb 29, 2008 | 02:09 PM
bbywu's Avatar
Talking
You know...I just don't get it. I installed this upgraded turbocharger in my 997TT, and the service manager came out to me in the waiting room and said my warranty would be voided.
Old Feb 29, 2008 | 03:36 PM
ZEMDOGG's Avatar
ZEMDOGG is infamous around these parts
bbywu, why so small?
I would think if you were going to upgrade you would at least want more than 10,000 horsepower! lol
