EVOMS Boost Recirculation Valves Available
Old Mar 19, 2008 | 07:08 PM
sharkster's Avatar
Hey folks, just a quick update for you... We've recently started adding EVOMS' new Boost Recirculation Valve kit to any/all 997TT's whether it's for 550-700. Those of you familiar with the DV's on 996TT sort of know the drill. Their BRV eliminates issues of boost leaks and diaphragm sticking and deterioration that can occur with the OEM valves over time. It's also got improved boost recovery in-between shifts. If you've got more than stock boost these will certainly do the job over time. For further info check the site or just Email to alex@sharkwerks.com
http://www.sharkwerks.com/products.php?pid=170
Old Mar 19, 2008 | 10:50 PM
chrisn's Avatar
chrisn is a name known to allchrisn is a name known to allchrisn is a name known to allchrisn is a name known to allchrisn is a name known to allchrisn is a name known to all
Not sure what it does, but please add one to my 700HP kit. ;-)
Old Mar 19, 2008 | 11:17 PM
sharkster's Avatar
Hey Chris lol.... You bet. It really will be a good/preventative measure. Also doesn't bleed boost as noticeably as the stocker between shifts....
Old Mar 19, 2008 | 11:48 PM
sharkster's Avatar
Originally Posted by m3_il
are these louder than stock? how hard is install
Hi m3_il no they don't seem to be (all the cars have exhausts so). Install is quite easy... one rear wheel has to come off.
Old Mar 20, 2008 | 06:33 AM
eclou's Avatar
eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !
Passenger side DV is easy to R&R. Driver's side is a touch more difficult. I had to remove the wheel and fender liner as well as the compressor intake pipe. You need a 1/4 drive 10mm socket with a universal joint.
Greehn
Sep 16, 2015 04:45 PM
maroli
Sep 15, 2015 07:07 PM
johnny.dangerous
Sep 11, 2015 02:39 PM
Gunther
Sep 10, 2015 10:30 AM
ECS Tuning - VW
Sep 8, 2015 12:54 PM
