turbo wheels
Old Jun 14, 2008 | 12:10 PM
coolwater3's Avatar
coolwater3 is infamous around these parts
turbo wheels
can i take 997 turbo wheels and mount them on a 997 c2? if so, will evderyhting be safe? thanks
Old Jun 14, 2008 | 12:18 PM
OCPorsche's Avatar
OCPorsche is infamous around these parts
You can as long as they came off a standard body (not wide body) car. The rear wheels are different
Old Jun 14, 2008 | 12:33 PM
coolwater3's Avatar
clarification
I mean can I take the turbo wheels off of a a 2008 911 Turbo and mount them on a 2008 911 c2. From what I undesrtnd, the turbo is a wide body and the c2 is a narrow body,"... I was told it can be done without any real difference - is this accurate ? Thx
Old Jun 14, 2008 | 12:55 PM
gmoney's Avatar
its inaccurate.
Old Jun 14, 2008 | 01:59 PM
TT Surgeon's Avatar
No not on a c2s, but yes on a c4s, offsets are different.
Old Jun 14, 2008 | 02:06 PM
meaker's Avatar
meaker is a splendid one to beholdmeaker is a splendid one to beholdmeaker is a splendid one to beholdmeaker is a splendid one to beholdmeaker is a splendid one to beholdmeaker is a splendid one to beholdmeaker is a splendid one to beholdmeaker is a splendid one to behold
Yes you can....... I had aftermarket rims with a 50mm offset on a narrow body(thier is pic in the forsale section under Avus 501) and they did not stick out from under the fender so 51mm will not either.....
Old Jun 14, 2008 | 02:11 PM
TT Surgeon's Avatar
The fronts are close enuff at 51, but the rear et is the problem, 63 nb and 47 wide I believe.
c
Old Jun 14, 2008 | 02:17 PM
Speedshaq's Avatar
Speedshaq Is a GOD !Speedshaq Is a GOD !Speedshaq Is a GOD !Speedshaq Is a GOD !Speedshaq Is a GOD !Speedshaq Is a GOD !Speedshaq Is a GOD !Speedshaq Is a GOD !Speedshaq Is a GOD !Speedshaq Is a GOD !Speedshaq Is a GOD !
Originally Posted by gmoney
its inaccurate.
+1...
Old Jun 14, 2008 | 02:26 PM
meaker's Avatar
Are the stock turbo wheels not 51mm offset? if so it will work. This pic is off 50mm offset on a narrow body.....
Old Jun 14, 2008 | 02:48 PM
coolwater3's Avatar
there are 2 components to this...the rims and the tires- i'm undestanding taht the rim and tire package might be too wide for the rear of a c2, but can put the correct size tire on the wide rim so that everything will be A OKAY?- thanks
Old Jun 14, 2008 | 07:37 PM
meaker's Avatar
In the pic of my car is a 305/25/20 on a narrow body car with 50mm offset.... It can be done ask Raffi..
Old Jun 15, 2008 | 06:10 AM
coolwater3's Avatar
is it possible to simply put 4 front wheels from the 911 turbo onto a narrow-body 997 ?
Old Jun 15, 2008 | 06:29 AM
SRatha's Avatar
SRatha has much to be proud ofSRatha has much to be proud ofSRatha has much to be proud ofSRatha has much to be proud ofSRatha has much to be proud ofSRatha has much to be proud ofSRatha has much to be proud ofSRatha has much to be proud ofSRatha has much to be proud ofSRatha has much to be proud of
yeah i believe it's possible but the back wheel would look really funny
Old Jun 15, 2008 | 07:05 AM
coolwater3's Avatar
funny in what way? i can put wider tires or not? maybe i need spacers then? thansk
Old Jun 15, 2008 | 07:24 AM
meaker's Avatar
You don't want to have a 8in wheel on the rear, that's what he laughing about. You would not be able to stick a wide enough tire on it,either... Did you not look at my pic? I can post more to show you that 50mm offset will work with a 305 tire on a narrow body car.. If I'm correct that the turbo wheel is 1mm less then what I had, so it will fit...
PelicanParts.com
964 Turbo
Aug 18, 2015 03:56 PM
PelicanParts.com
993 Turbo Vendor Classifieds
Aug 18, 2015 03:55 PM
PelicanParts.com
991 Turbo Vendor Classifieds
Aug 18, 2015 03:47 PM
PelicanParts.com
996 Turbo Vendor Classifieds
Aug 18, 2015 03:43 PM
PelicanParts.com
GT3/GT2/GT Vendor Classifieds
Aug 18, 2015 03:42 PM
