HRE P43 Wheels Reading -4 lbs On TPC
Old Jun 16, 2008 | 06:28 PM
Barrister's Avatar
Barrister is a splendid one to beholdBarrister is a splendid one to beholdBarrister is a splendid one to beholdBarrister is a splendid one to beholdBarrister is a splendid one to beholdBarrister is a splendid one to behold
My new 20" HRE P43s are consistently reading -4 lbs psi in the passenger rear. This is so even though my very accurate hand gauge says it is 40 lbs. If I reset the TPC program it goes away for a while but then comes back after the car sits for a bit. I assume it reads low once they cool off and the air contracts.
This is bugging the hell out of me. I suppose it could be a bad sensor in the tire. I don't think it is losing air because it has been doing it for a week and the tire is not low at all.
Any ideas?
Old Jun 16, 2008 | 06:34 PM
alexWS6's Avatar
alexWS6 has much to be proud ofalexWS6 has much to be proud ofalexWS6 has much to be proud ofalexWS6 has much to be proud ofalexWS6 has much to be proud ofalexWS6 has much to be proud ofalexWS6 has much to be proud ofalexWS6 has much to be proud of
Pressures sensors are often an issue on larger diameter/smaller sidewall setups. HRE has surely encountered this and could have a quick solution for you
Old Jun 16, 2008 | 06:50 PM
LA TECH's Avatar
LA TECH is infamous around these parts
It's not an issue with the wheel. It's an issue with the sensor. Dismount the tire clean off the sensor of any tire mounting lubricant or obstruction and it should return to reading properly. Whomever mounted these should fix it free of charge. If it continues to read improperly you will need a new sensor. Good luck
Old Jun 16, 2008 | 07:43 PM
silversrt's Avatar
silversrt has a spectacular aura aboutsilversrt has a spectacular aura aboutsilversrt has a spectacular aura about
sensors
I disagree with the bad sensor post. My new HREs, 20's 547s, do exactly the same thing. Rears read a little low 4-5# although my handheld gauge reads right on the money. Not losing any air but they BOTH are about the same, -4-5# consistently on the TPMS system. If it were a bad sensor it would only show in one wheel I believe. I havent the foggiest why this is but since I know they are not leaking and show the same for both rears, Ive grown to not care what the TPMS system says anymore allthough it is a slight bit annoying. If all of a sudden one rear read -10#, I would know there is a problem.
To be honest, pressure sensors are a friggin joke anyways. Half the times people are having problems with them and the other half you cant trust em anyways. I'll just take my chances with the old seat of the pants feel when I get a flat.
Old Jun 16, 2008 | 10:51 PM
Barrister's Avatar
Yeah. But its that damn red exclamation point that bugs me. I see it and I start looking for check engine lights. I am OCD about stuff like that.
Old Jun 17, 2008 | 02:31 AM
M3 S3-R's Avatar
M3 S3-R is a jewel in the roughM3 S3-R is a jewel in the roughM3 S3-R is a jewel in the rough
Wow sorry to hear you guys are having trouble. Good luck with HRE's customer service. Keep us posted of the out come.
Old Jun 17, 2008 | 09:12 AM
HREMarc's Avatar
HREMarc is infamous around these parts
Barrister,
Call Betim at BBI and have him remove/inspect and re install the sensor. May have been damaged while installing. That is the best first step.
Marc
Old Jun 17, 2008 | 09:18 AM
gmoney's Avatar
Is there something in the nav / computer that allows changing of settings for this? Like most I speed read through the manual but I swore I saw something regarding this. Will check.
Old Jun 17, 2008 | 09:27 AM
Barrister's Avatar
Just checked the tires after leaving it over night. My handheld gauge says no loss of air. So it must be in the sensor. I have not driven it yet. We'll see if it still reads -4.
Old Jun 17, 2008 | 12:23 PM
Barrister's Avatar
Checked the car and the passenger rear is find but now the driver's side rear reads -5!!! This is getting ridiculous.
So, I filled the driver's side rear with a few pounds, made it equal with the passenger side rear (40 lbs in each) and reset the TPC system. Right now it reads properly. I hope it stays that way or I am going to have to take it back to BBI and have them check it out.
I have a question for you guys as well. Does it make much difference if you change the settings in the TPC to either Summer or Winter Tires? And how about the Partial vs Full Load setting. Mine was set for Summer Tires and Full Load. Most importantly, is there a way I can just turn the TPC off? I never look at it and prefer to take the readings with my handheld gauge.
Thanks for all the help.
Old Jun 17, 2008 | 12:47 PM
speedoflight's Avatar
speedoflight has much to be proud ofspeedoflight has much to be proud ofspeedoflight has much to be proud ofspeedoflight has much to be proud ofspeedoflight has much to be proud ofspeedoflight has much to be proud ofspeedoflight has much to be proud ofspeedoflight has much to be proud ofspeedoflight has much to be proud of
barrister,
mines is off by ~-4psi. i have stock wheels. i recall reading it in rennlist that the dealer can turn this 'feature' off. check with your local dealer.
btw, nice wheels!
Old Jun 17, 2008 | 12:55 PM
03-turbo911's Avatar
Senior Member
It can be turned off at you dealer using the PIWIS.
Old Jun 17, 2008 | 01:28 PM
eclou's Avatar
eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !
Beru instructs the sensors to be installed with the sample holes pointed radially outward from the center axis. When I removed the old sensors and put them on my new wheels some of the old ones were oriented the opposite way so the holes pointed inward which may have caused errors.
Old Jun 18, 2008 | 12:37 AM
Barrister's Avatar
Thanks for all the help guys. After I put some air in the tires this morning and reset the system, I have yet to get an error. I am keeping my fingers crossed.
Old Jun 18, 2008 | 08:57 AM
DesertCaymanS's Avatar
DesertCaymanS is infamous around these parts
Had same issue with my custom wheels and lower profile tires - filled them with nitrogen and no more false readings since the heat ed gas expands less than air.
