997TT won't run on DYNOPACK..
Old Jan 2, 2009 | 02:31 PM
GT3Ranger's Avatar
GT3Ranger Is a GOD !GT3Ranger Is a GOD !GT3Ranger Is a GOD !GT3Ranger Is a GOD !GT3Ranger Is a GOD !GT3Ranger Is a GOD !GT3Ranger Is a GOD !GT3Ranger Is a GOD !GT3Ranger Is a GOD !GT3Ranger Is a GOD !GT3Ranger Is a GOD !
I must be dense and I apologize but I am still not clear on the Dynapack dyno functioning.
How does it record whp when there are no factors of wheel / tire weight and surface rolling resistence?
How does the issue of drivetrain loss factor into play or if it does at all?
It seem to me that it would yield a higher hp figure?
How does this all compare to a Dynojet dyno which has not been mentioned?
Thank you
Ranger
Old Jan 2, 2009 | 03:04 PM
deputydog95's Avatar
deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !
IT connects directly to the wheel hub and uses hydraulics to create resistance in lieu of a weighted drum.
It's the same as any other dyno. However, drum weight inconsistencies, tire pressures, strap tension, and all the other normal roller dyno variables don't come into play.
No, they're generally lower but very very consistent. They also offer the ability to hold a certain rpm so that you can due real time fuel mapping.
See my above responses
Thank you
Ranger
fdjlfsjflsjdflsjdfljsldfjlsdjflsjdflsdjfljs
PV=nRT.
Sep 9, 2022 06:06 PM
danyoP4S
Sep 30, 2021 05:06 AM
shifter_
Sep 8, 2015 12:07 PM
Fester
Sep 8, 2015 09:35 AM
