Rotor Replacement (Track + Street Use)
Old Jan 18, 2009 | 01:25 PM
eclou's Avatar
eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !
My original drilled rotors lasted more than 10 weekends on the track. I don't run 10/10ths but I don't think people buy TT's to run as 10/10th track cars.
Old Jan 18, 2009 | 02:58 PM
TT Gasman's Avatar
TT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant future
I just changed my pads, the rotors were still good, I have approx 6 track weekends on them. Next up is a flush and bleed with some fresh GS 610 fluid and I should be good to go.
Old Jan 18, 2009 | 03:27 PM
TT Surgeon's Avatar
About 20 track days on my stock rotors in the red group, grooved a bit but still ok. When they're done I'll probably just put some stockers back on.
c
Old Jan 18, 2009 | 05:29 PM
raiyu's Avatar
raiyu is a splendid one to beholdraiyu is a splendid one to beholdraiyu is a splendid one to beholdraiyu is a splendid one to beholdraiyu is a splendid one to beholdraiyu is a splendid one to beholdraiyu is a splendid one to behold
Ive done about 20 track days in my car, the problem is the cracks. Just about every hole has cracks coming from it. None are going to the edge yet and I still have rotor left, but Thom at Porsche of Huntington said if he was teching my car he wouldn't clear me with the rotors I have on now.
I really dont need an upgrade in braking performance so I think I'll just compare the price of the AP and the RSS and go from there, if there isn't much difference I'll give the RSS a try, otherwise AP.
Old Jan 19, 2009 | 11:19 AM
Gary II's Avatar
Gary II is a glorious beacon of lightGary II is a glorious beacon of lightGary II is a glorious beacon of lightGary II is a glorious beacon of lightGary II is a glorious beacon of lightGary II is a glorious beacon of light
Originally Posted by TT Surgeon
The RSS ones are 2400 set of 4. they have been used by many ALMS series teams for several years.
Do you know the names of any of the ALMS teams that are using those discs?
Old Jan 19, 2009 | 11:37 AM
Gary II's Avatar
Originally Posted by raiyu
So if I get this right we basically have the following: (This is mostly from the perspective of track with some street)
Brembo 2pc floating
Price: est $3600 a set
Benefit: Its brembo, its 2pc, 'nuff said
Con: costs about an arm and a leg, and I'm assuming the replacement rotors without the hats will cost roughly the same as AP slotted.
This sound about right?
That price would be for a set of FRONT & REAR.
We are only a week or so away from the rears being available.
Front alone retails for $1895.
The cost is pretty much in line with the AP units I was originally talking about, only a tad bit more because of the McLaren style hardware Brembo uses that allows them to be full floating.
(I think there's more than one AP version out there)
For any of the other options out there, I would be curious where they are getting their discs from. The quality of the disc is going to dictate the longevity, and the longevity is what is going to make them a value or not.
Weight savings alone does not justify the cost for any of these brands. The weight savings, plus the benefit of being full floating, combined with the benefit of lasting twice as long as the OEM discs, definitely does.
Old Jan 20, 2009 | 01:17 PM
landjet's Avatar
Just for your interest--- DeMan Motorsports--High Performance One Piece GT3 Rotors
2 times the life of factory rotors, fits 997 GT3 Street 06-08, GT3 Cup 02-05, 996 GT3 Street 04-05, $695 per pair, http://www.demanmotorsport.com
No affiliation blah, blah, blah. Never tried them, just thought you might like to see these.
Old Jan 20, 2009 | 08:05 PM
joyride's Avatar
joyride has a spectacular aura aboutjoyride has a spectacular aura aboutjoyride has a spectacular aura about
Deman's GT3 fotor does not work on the Turbo. The offset is different.
Old Jan 21, 2009 | 10:06 AM
landjet's Avatar
Sorry, I upgraded to GT3 brakes and wasn't thinking about the turbo aspect.
Old Jan 21, 2009 | 12:47 PM
joyride's Avatar
You pulled the front diff and changed out to GT3 hub/wheel bearing?
Old Jan 21, 2009 | 01:11 PM
landjet's Avatar
No, just changed the calipers and rotors. Since then I have to think of GT3 parts when I think about brakes, therefore the mix-up.
Old Jan 26, 2009 | 12:53 PM
The Turbo's Avatar
The Turbo is infamous around these partsThe Turbo is infamous around these parts
20 track days? Hell, just buy OEMs and be done with it.
What pads are you using? Try the Pagid Yellows..........here is a good place for those:
www.Rennstore.com
Old Jan 26, 2009 | 02:23 PM
raiyu's Avatar
Switched to Pagid Blacks after about the first 7-10 track days. I'm definitely going to go with a slotted rotor, just need to figure out which one.
Also, my car gave me the Brake Pad Sensor warning today, but I checked my pads and I have a ton of pad left, can the sensor go off for rotor wear?
Old Jan 26, 2009 | 03:35 PM
The Turbo's Avatar
Mine went off when I had more than 30% or so left.
You might have pad taper - one section of the pad more worn than the other.
I'd take them off and take a look.
Old Jan 26, 2009 | 07:29 PM
TT Surgeon's Avatar
That happened once on my old c4s, the sensors had melted when the fluid boiled at limerock.
Also make sure your wires aren't loose or contacting metal.
Jul 29, 2019 11:13 AM
The_Ruski_Driver
Oct 25, 2015 08:40 PM
TrackOne
Aug 20, 2015 12:56 PM
pwdrhound
Aug 20, 2015 05:54 AM
