How to launch the manual 997 TT ?
Old Feb 1, 2009 | 10:23 PM
bbywu's Avatar
Originally Posted by nyamg
Sorry for the dumb question, but what are rep bars?
Little green or red squares on the right...
Old Feb 1, 2009 | 10:29 PM
yrralis1's Avatar
Originally Posted by bbywu
Well, I suck at the drag strip. The 997TT's clutch activation is difficult for me to master...
With a stage 3 clutch its even harder . I look forward to the Gt2 conversion that I will be getting with the hopes that the adjustments will provide a more accurate clutch feel .
Old Feb 2, 2009 | 12:09 AM
art4iza's Avatar
art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !
Agree with slipping the clutch rather than dropping the clutch. You need to practice this at the drag strip, totally different when you are behind the light. Heart starts pumping hard especially if a car next to you is burning the **** out of their tires. Practice, practice, GL.
Old Feb 2, 2009 | 04:00 AM
SRatha's Avatar
SRatha has much to be proud ofSRatha has much to be proud ofSRatha has much to be proud ofSRatha has much to be proud ofSRatha has much to be proud ofSRatha has much to be proud ofSRatha has much to be proud ofSRatha has much to be proud ofSRatha has much to be proud ofSRatha has much to be proud of
Looking at what you're up against while he is burning the living life out of his tires is just doing nothing but shrinking your own *****! next time don't look just concentrate
Old Feb 2, 2009 | 11:11 AM
imcarnuts's Avatar
imcarnuts Is a GOD !imcarnuts Is a GOD !imcarnuts Is a GOD !imcarnuts Is a GOD !imcarnuts Is a GOD !imcarnuts Is a GOD !imcarnuts Is a GOD !imcarnuts Is a GOD !imcarnuts Is a GOD !imcarnuts Is a GOD !imcarnuts Is a GOD !
Try and get a shredded tranny or a broken axle covered under warranty and see what they say...
And BTW, go Cardinals
Steelers 27 - Cardnals 23
And where are those Packers
Old Feb 2, 2009 | 07:09 PM
art4iza's Avatar
I'm just trying to teach from my learnings. It is always good to look ahead only but sometimes the ground shaking next to you does not help much
Old Feb 2, 2009 | 09:29 PM
chrisn's Avatar
chrisn is a name known to allchrisn is a name known to allchrisn is a name known to allchrisn is a name known to allchrisn is a name known to allchrisn is a name known to all
I have only launched mine a few times (probably terribly). I always get that nasty clutch smell and it makes me feel a little guilty/dirty. I usually baby the car for the rest of the day....
I get my kicks with a good 2nd gear pull.
Old Feb 2, 2009 | 09:34 PM
nyamg's Avatar
nyamg has much to be proud ofnyamg has much to be proud ofnyamg has much to be proud ofnyamg has much to be proud ofnyamg has much to be proud ofnyamg has much to be proud ofnyamg has much to be proud ofnyamg has much to be proud ofnyamg has much to be proud of
I know exactly what your talking about..
Old Feb 2, 2009 | 09:58 PM
bbywu's Avatar
They were robbed.
Old Feb 2, 2009 | 10:05 PM
gmoney's Avatar
flash the ecu, add the exhaust of your choosing and dont worry about launching and abusing the clutch....you will be plenty fast just softly launching the car and keeping your foot down from then on out.
Old Feb 2, 2009 | 10:06 PM
gmoney's Avatar
and for the record the Steelers planned that whole game out from the get go
Old Feb 3, 2009 | 04:22 AM
turbo498's Avatar
turbo498 is infamous around these parts
Thanks guys for all you responces..so i understand that i should rev the engine 3-4k rpm and then drop the clutch and full throttle ? simply drop the clutch. Some guys are stating slip the clutch rather than dropping it, can somebody illustrate in detail how to slip the clutch ?
Old Feb 3, 2009 | 08:40 AM
gmoney's Avatar
I would highly recommend slipping the clutch, good chance you will bog dropping at 3-4k
Old Feb 4, 2009 | 11:58 AM
noah677's Avatar
noah677 is infamous around these parts
Y1
Do you mean you are going to dump the AWD by a GT2 conversion???
Old Feb 4, 2009 | 03:38 PM
GotBoost?'s Avatar
GotBoost? Is a GOD !GotBoost? Is a GOD !GotBoost? Is a GOD !GotBoost? Is a GOD !GotBoost? Is a GOD !GotBoost? Is a GOD !GotBoost? Is a GOD !GotBoost? Is a GOD !GotBoost? Is a GOD !GotBoost? Is a GOD !GotBoost? Is a GOD !
I usually do a soft launch. Not too many cars out there that can hang with you if your tt is modded.
