Condensation in Headlamp
Old Mar 12, 2009 | 10:15 AM
Qs997Turbo's Avatar
Qs997Turbo is infamous around these parts
With all this rain we have been experiencing in Texas, I noticed that the lower part of my headlamps have been fogging up. The condensation dissapears after about 15 minutes in the garage. Is this typical? I did a search on the forum and a member awhile back had posted that there are vents in the back of the headlamps in which moisture can come in and exit.
Old Mar 12, 2009 | 10:46 AM
David9962000's Avatar
David9962000 has a reputation beyond reputeDavid9962000 has a reputation beyond reputeDavid9962000 has a reputation beyond reputeDavid9962000 has a reputation beyond reputeDavid9962000 has a reputation beyond reputeDavid9962000 has a reputation beyond reputeDavid9962000 has a reputation beyond reputeDavid9962000 has a reputation beyond reputeDavid9962000 has a reputation beyond reputeDavid9962000 has a reputation beyond reputeDavid9962000 has a reputation beyond repute
It's probably the seal around the headlight.
Old Mar 12, 2009 | 11:12 AM
gmoney's Avatar
Common, not necessarily the seal. Humidity does it, make sure the breathing holes are not clogged on the back. Its impossible to prevent in places like TX, I tell you that much!
Pull the little rubber hose off and check for clogs on the plastic part of the lamp assembly, there is a paper piece sometimes it is not removed at the factory which prevents the lamp from breathing - even the sidemarkers have the breathers and the two pairs Ive seen (the clear ones) were clogged from the get go.
Old Mar 12, 2009 | 12:14 PM
Porsche917's Avatar
Porsche917 is a splendid one to beholdPorsche917 is a splendid one to beholdPorsche917 is a splendid one to beholdPorsche917 is a splendid one to beholdPorsche917 is a splendid one to beholdPorsche917 is a splendid one to behold
its normal, with the heat generated inside the headlamp housing they have to be vented.
7thsign
Dec 12, 2015 07:43 PM
whtrabt
Oct 5, 2015 05:23 PM
WEEED
Cayenne
Sep 25, 2015 10:45 PM
mike@mautolite
Macan Vendor Classifieds
Sep 23, 2015 06:59 PM
cerbomark
Sep 22, 2015 03:32 PM
