Values To Datalog in Durametric
Old Mar 12, 2009 | 01:10 PM
Turbo Fanatic's Avatar
Ok so i got Durametric.
I want to log
RPM (easy)
A/F Ratios (don't know which box to check) I prefer actual ratio (like a dyno) if possible
Boost not sure if this will show in BAR or PSI? Which box do I check?
Timing
Which boxes should I check?
The confusion is that there seems many different parameters for some of these values.
Thanks for any help!
Old Mar 13, 2009 | 04:56 PM
unvmy996's Avatar
rpm engine load , boost actual % i think thats what it sais, AF is shown as actual lambda bank1 and 2. timing is shown as iginition angle ,
Old Mar 13, 2009 | 09:59 PM
Thanks!
Old Mar 14, 2009 | 04:29 PM
Al Norton's Avatar
Al Norton has much to be proud ofAl Norton has much to be proud ofAl Norton has much to be proud ofAl Norton has much to be proud ofAl Norton has much to be proud ofAl Norton has much to be proud ofAl Norton has much to be proud ofAl Norton has much to be proud of
The lambda readings are no good at high RPM's. The sampling rate is too slow.
Old Sep 27, 2009 | 07:28 PM
justatoy's Avatar
justatoy Is a GOD !justatoy Is a GOD !justatoy Is a GOD !justatoy Is a GOD !justatoy Is a GOD !justatoy Is a GOD !justatoy Is a GOD !justatoy Is a GOD !justatoy Is a GOD !justatoy Is a GOD !justatoy Is a GOD !
This may be a stupid question BUT how does timing angle compare to ignition timing?
Or are they the same?
Are they 1 to 1...?
If I am showing a timing angle of 15 at 6000 rpm in my Durametric......what would that number be to ignition timing?
Thanks guys and sorry if it is a dumb question,
Stacy
White991TT
Mar 8, 2016 06:01 AM
FUTURESTAR
BMW //M
Nov 18, 2015 10:37 PM
COBB Tuning
Nov 3, 2015 08:39 AM
Frank ( Sunnyside )
Bentley
Oct 3, 2015 11:13 PM
gjpearce
Sep 30, 2015 04:26 AM
