Negative Front Camber : Control Amrs vs Camber Plates
Old Mar 17, 2009 | 09:08 AM
raiyu's Avatar
raiyu is a splendid one to beholdraiyu is a splendid one to beholdraiyu is a splendid one to beholdraiyu is a splendid one to beholdraiyu is a splendid one to beholdraiyu is a splendid one to beholdraiyu is a splendid one to behold
I'm looking to get a bit more negative front camber.
I was wondering what are the differences between using camber plates vs adjustable control arms. Are there any benefits/negatives to either setup?
Also, I was told that the 997TT has a nonstandard mount point for the front suspension, so if you wanted to use standard camber plates that work fine on a 997 or cayman/boxster layout you need to get additional hardware. Is this safe for track applications?
I got about -1.5 rear camber and got the adjustable toe links from RSS, so looking to get just above that for my front camber and have the ability to increase it overtime as the need arises. Dont want to go above -2 front initially.
Old Mar 17, 2009 | 10:56 PM
luiscarlos's Avatar
luiscarlos has much to be proud ofluiscarlos has much to be proud ofluiscarlos has much to be proud ofluiscarlos has much to be proud ofluiscarlos has much to be proud ofluiscarlos has much to be proud ofluiscarlos has much to be proud ofluiscarlos has much to be proud of
I have CUP or RS front and rear control arms and I think they are better than canberplates since you can get a wider front track and adjust camber in the top,in other words control arms are a more flexible setup.
Old Mar 18, 2009 | 08:32 AM
jamuz's Avatar
jamuz is a splendid one to beholdjamuz is a splendid one to beholdjamuz is a splendid one to beholdjamuz is a splendid one to beholdjamuz is a splendid one to beholdjamuz is a splendid one to beholdjamuz is a splendid one to beholdjamuz is a splendid one to behold
raiyu, i have control arms up front too, run over 2deg camber.
i think u can kinda see in pic
Old Mar 18, 2009 | 06:20 PM
raiyu's Avatar
What company makes control arms for the 997TT ?
Old Mar 18, 2009 | 06:38 PM
luiscarlos's Avatar
tarett sales them
Jul 29, 2019 11:13 AM
Enemy
Nov 10, 2015 08:01 AM
orbelo
Aug 30, 2015 12:26 PM
The Oss
Aug 24, 2015 08:19 PM
TrackOne
Aug 20, 2015 12:56 PM
