Boost Recirculation Valve
Old Feb 19, 2011 | 07:25 AM
  #31
milou's Avatar
milou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond repute
Originally Posted by GT-TT
Yes could even a bit more as durametric shows 1.55 constant from 3.6 to 7.8k.
This is the limit of ecu. I have camp ported heads rods big VTgs
Are your VTGs mooded or other bigger than stock?
Old Feb 19, 2011 | 09:01 AM
  #32
Swole Powell's Avatar
Swole Powell Is a GOD !Swole Powell Is a GOD !Swole Powell Is a GOD !Swole Powell Is a GOD !Swole Powell Is a GOD !Swole Powell Is a GOD !Swole Powell Is a GOD !Swole Powell Is a GOD !Swole Powell Is a GOD !Swole Powell Is a GOD !Swole Powell Is a GOD !
I installed brv's and im not impressed, Didnt gain anything and spool seems the same. Now when I let off the gas after a WOT run and push the clutch in the car rpms drop to like 300rpm or dies? Maybe I have a vacuum leak but I log the car and the boost is prefect and so are the a/f's.
Old Feb 19, 2011 | 09:04 AM
  #33
venkatreddytx's Avatar
venkatreddytx has a reputation beyond reputevenkatreddytx has a reputation beyond reputevenkatreddytx has a reputation beyond reputevenkatreddytx has a reputation beyond reputevenkatreddytx has a reputation beyond reputevenkatreddytx has a reputation beyond reputevenkatreddytx has a reputation beyond reputevenkatreddytx has a reputation beyond reputevenkatreddytx has a reputation beyond reputevenkatreddytx has a reputation beyond reputevenkatreddytx has a reputation beyond repute
Stock are best and have show to be reliable and most tuners ask to leave stock BRV's.
Had after market BRV's and my tuner(Todd) had me switch back to stock.
Old Feb 19, 2011 | 09:07 AM
  #34
drsullivan's Avatar
drsullivan has a brilliant futuredrsullivan has a brilliant futuredrsullivan has a brilliant futuredrsullivan has a brilliant futuredrsullivan has a brilliant futuredrsullivan has a brilliant futuredrsullivan has a brilliant futuredrsullivan has a brilliant futuredrsullivan has a brilliant futuredrsullivan has a brilliant futuredrsullivan has a brilliant future
I would take them both off and make sure the small window in the BRV mates with the opening in the turbo - I think they are easy to improperly install.
Old Feb 19, 2011 | 10:05 AM
  #35
Arone997tt's Avatar
Arone997tt has much to be proud ofArone997tt has much to be proud ofArone997tt has much to be proud ofArone997tt has much to be proud ofArone997tt has much to be proud ofArone997tt has much to be proud ofArone997tt has much to be proud ofArone997tt has much to be proud ofArone997tt has much to be proud ofArone997tt has much to be proud of
i had after market ones also also, CMS told me to switch back to stock,car is making around 700whp
Old Feb 19, 2011 | 12:34 PM
  #36
GT-TT's Avatar
GT-TT is infamous around these partsGT-TT is infamous around these parts
Yes GT2 VTGs with 59.8 compressor side. Boost over 1.55bar
Old Feb 19, 2011 | 01:11 PM
  #37
milou's Avatar
Wow, who is your tuner? Post some times to compare
Old Feb 19, 2011 | 01:37 PM
  #38
997 GT3 RS/TT's Avatar
997 GT3 RS/TT has a reputation beyond repute997 GT3 RS/TT has a reputation beyond repute997 GT3 RS/TT has a reputation beyond repute997 GT3 RS/TT has a reputation beyond repute997 GT3 RS/TT has a reputation beyond repute997 GT3 RS/TT has a reputation beyond repute997 GT3 RS/TT has a reputation beyond repute997 GT3 RS/TT has a reputation beyond repute997 GT3 RS/TT has a reputation beyond repute997 GT3 RS/TT has a reputation beyond repute997 GT3 RS/TT has a reputation beyond repute
hmm you mixed up again.
you can have max 49,8.
btw his car is fast for vtg's car I think.
Old Feb 19, 2011 | 01:39 PM
  #39
and one more thing....compressor size is nothing special as turbine wheel is still same....
Old Feb 19, 2011 | 01:57 PM
  #40
GT-TT's Avatar
err yes karol is right, i meant 49.8mm compressor side. I wish someone could make vtgs with turbine wheels a few mm bigger to match the bigger cold side.
Car is around 730hp 950nm, 100-200 5.2sec best so far, 200-300 in 13 with extra weight, so 12 may be possible or better with better ICs.
Cams, rods, ported head, gt2 intake & exhaust with 100m cell and flaps.
Probably v close to the limit you can get with vtgs.
For the money spent i could have had a lot more power but wanted to stay with factory systems as much as possible. (ie VTGs)
Old Feb 19, 2011 | 02:01 PM
  #41
100-200 1 shift?
have you tried no shift?
Old Feb 19, 2011 | 02:04 PM
  #42
GT-TT's Avatar
not yet..
When i settle on ICs and put again that open intake system i ll try it.. That is if gearbox will be able to take the additional torque with that intake
Old Feb 19, 2011 | 02:16 PM
  #43
here is my spare one
Old Feb 19, 2011 | 02:24 PM
  #44
K24F's Avatar
K24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond repute
Safe with 1000Nm...
Old Feb 19, 2011 | 02:52 PM
  #45
Originally Posted by K24F
Safe with 1000Nm...
I have spare engine too
