Does your car act up in hot weather?
Old Aug 18, 2009 | 09:17 PM
KA 997TT's Avatar
KA 997TT has a reputation beyond reputeKA 997TT has a reputation beyond reputeKA 997TT has a reputation beyond reputeKA 997TT has a reputation beyond reputeKA 997TT has a reputation beyond reputeKA 997TT has a reputation beyond reputeKA 997TT has a reputation beyond reputeKA 997TT has a reputation beyond reputeKA 997TT has a reputation beyond reputeKA 997TT has a reputation beyond reputeKA 997TT has a reputation beyond repute
It is the hottest summer on record for Central Texas and i get some hiccups through the RPM's when I get on it a bit, it does not seem to do it as much when it is cooler outside.
What is your take on this?
What is the optimum temperature to get a the best performance out of the car?
Old Aug 18, 2009 | 10:37 PM
gmoney's Avatar
Turbo cars dont like the heat at extreme levels your seeing, I bet your just seeing the car pull back a bit. I believe you could run better gas (higher octane race type) and see if that helps.
The cooler denser air is the best.
Old Aug 18, 2009 | 10:46 PM
KA 997TT's Avatar
is 82 degrees too hot? what would be really good?
what Octane would you run? 98, 100 or 103?
Old Aug 18, 2009 | 11:01 PM
gmoney's Avatar
82, no, I was thinking your talking about 100+
82 should be A ok even with your mods. Who tuned your car?
Old Aug 19, 2009 | 03:58 PM
KA 997TT's Avatar
it has a Softronic tune. I am trying to figure out how to fix the issue with them.
Old Aug 19, 2009 | 04:04 PM
bbywu's Avatar
You have Dan's upgraded VTG package right?
What do you mean by hiccup?
Old Aug 19, 2009 | 04:12 PM
KA 997TT's Avatar
It is like a surge... the turbos are spooling fast, the car is trying to digest the power, it pushes it back then it takes it in and it is happening fast, it feels like a hiccup or a freeze then as if you are getting pushed back in your seat when the power is in again...this was explained to me by an expert trying to help me communicate this to Softronic as i am not a mechanic... we need some more data log to go forward but I may have a solution soon...
Old Aug 19, 2009 | 04:49 PM
raclaims's Avatar
raclaims is a splendid one to beholdraclaims is a splendid one to beholdraclaims is a splendid one to beholdraclaims is a splendid one to beholdraclaims is a splendid one to beholdraclaims is a splendid one to beholdraclaims is a splendid one to behold
My car isn't as "aggressive" in the heat but nothing like what you are saying...and by heat I mean excess of 90 degrees.
Old Aug 19, 2009 | 04:55 PM
KA 997TT's Avatar
It gets worse with heat but it did the same thing at about 82 degrees a few days ago
Old Aug 19, 2009 | 05:11 PM
gmoney's Avatar
Did you replace the BRV's?
Old Aug 19, 2009 | 05:41 PM
KA 997TT's Avatar
and that part os? sorry
Old Aug 19, 2009 | 05:45 PM
gmoney's Avatar
http://www.youtube.com/watch?v=rC5HdrEgDOU
They say its a must do when your running higher boost vs. stock
Old Aug 19, 2009 | 05:47 PM
KA 997TT's Avatar
Dan sent me a set, i have not had the time to install it as i normally go to the local dealer for this, is it easy and do you recommend installing it myself?
Old Aug 19, 2009 | 05:51 PM
bbywu's Avatar
Do you have a durametric interface to log data?
Old Aug 19, 2009 | 05:55 PM
KA 997TT's Avatar
I got a lot of logged data about 8 files or so. I do not have the cable on me now...
