How Boost Recirculation Valves Install into the Turbos
Old Jan 17, 2010 | 09:13 AM
HN-GT2997's Avatar
HN-GT2997 is infamous around these parts
does someone have a dinosheet before and after?
greetings
Old Jan 17, 2010 | 09:18 AM
bbywu's Avatar
A dyno is a single gear WOT run. I do not believe that these valves should not affect the horsepower or torque curve on a dyno sheet.
Old Jan 17, 2010 | 09:21 AM
HN-GT2997's Avatar
mmmh so there is no gain in this?
just wondering as of the benefit of the valve holds the pressure better so there is no gain then? so then I maybe should keep the stock ones or is there something I understand wrong
Old Jan 17, 2010 | 09:22 AM
bbywu's Avatar
I didn't say there was no gain. I said that the dyno curve should not change. The benefits of this device would probably be best seen with a a datalog of the boost threshold as you shift between gears.
Old Jan 17, 2010 | 09:25 AM
HN-GT2997's Avatar
ah so you only get a benefit on accelerating when you change gears then, did you install them on your car? so far i did not find anything here in germany
Old Jan 17, 2010 | 09:31 AM
bbywu's Avatar
I'll let Dan answer these questions, as he can give you the specifics about his version of this modification.
Old Jan 17, 2010 | 09:33 AM
HN-GT2997's Avatar
cool thanks as I am starting to upgrade my GT2 so I would be happy to get some feedback about what makes it a better car
Old Jan 18, 2010 | 09:05 AM
vividracing's Avatar
If boost tapers off, you would lose that top RPM power. Also if boost is slow to respond, you would have a slower bottom torque curve. Would you see this on a dyno, maybe. Would you notice the improvements driving, absolutely.
Old Jul 29, 2012 | 06:27 PM
CarreraS997Blk's Avatar
CarreraS997Blk is infamous around these parts
good info thanks guys
BlackMarketRacing
Dec 8, 2015 01:49 PM
ECS Tuning - VW
Aug 19, 2015 08:58 AM
