Straight Pipes for 997tt
Old Sep 21, 2009 | 10:17 AM
Tom@Champion's Avatar
Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !
Sounds to me like you might be better off with a Tubi or Cargraphic exhaust system with cat-bypass pipes. That will give you exactly the effect you're looking for.
PM me if you'd like some prices or information.
Old Sep 21, 2009 | 09:16 PM
TT Surgeon's Avatar
To open up the stock 1 peice sytem and remove the 4 cats is a big undertaking,~5k to do it right. But, to what end?
Just buy a decent aftermarket system with cats, there are systems out there that have hi flow cats and can be tuned noise wise to your needs, ie FVD. 'Simply' removing the cats will add very little real world performance to a 3500# street car.
Old Sep 21, 2009 | 10:29 PM
cayenne_ksa's Avatar
cayenne_ksa has a reputation beyond reputecayenne_ksa has a reputation beyond reputecayenne_ksa has a reputation beyond reputecayenne_ksa has a reputation beyond reputecayenne_ksa has a reputation beyond reputecayenne_ksa has a reputation beyond reputecayenne_ksa has a reputation beyond reputecayenne_ksa has a reputation beyond reputecayenne_ksa has a reputation beyond reputecayenne_ksa has a reputation beyond reputecayenne_ksa has a reputation beyond repute
I have set of used FABSPEED by-pass cats pipes if you are interested
Old Sep 22, 2009 | 01:23 AM
HRTC's Avatar
HRTC is infamous around these parts
Thumbs up
Originally Posted by ///M PWR 00
Awesome
Old Sep 22, 2009 | 08:44 AM
Tiago's Avatar
Tiago is a splendid one to beholdTiago is a splendid one to beholdTiago is a splendid one to beholdTiago is a splendid one to beholdTiago is a splendid one to beholdTiago is a splendid one to beholdTiago is a splendid one to behold
I thought that the our cars had only 2x 600cpsi cats, one after each turbo...
My system is not much more loud than stock till 3000rpm. The only difference is that i can hear now the turbos. I doubt that the sound will be much more higher without the cats. If you don't care with the CEL light or will tune the ecu to clear the light, go for it.
Old Sep 22, 2009 | 04:23 PM
SRatha's Avatar
SRatha has much to be proud ofSRatha has much to be proud ofSRatha has much to be proud ofSRatha has much to be proud ofSRatha has much to be proud ofSRatha has much to be proud ofSRatha has much to be proud ofSRatha has much to be proud ofSRatha has much to be proud ofSRatha has much to be proud of
My car sounds like that without blowing up my ears to shred at idle. Don't ask for videos, I am away on studies for 7 more months...
Old Sep 22, 2009 | 04:28 PM
vividracing's Avatar
That is my car
Old Sep 22, 2009 | 04:56 PM
Old Sep 28, 2009 | 03:44 PM
ysfg35's Avatar
ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !
thanks guys for the info ...
i will mako the pipe 3 inchs
Old Sep 29, 2009 | 05:29 AM
Tiago's Avatar
I don't see the need to make that. Just open the stock system in the welds near to the turbo flange, clean the cats inside and weld it again. I opened my system through the welds carefully to remove the OE cats and end up messing them, so don't care about it. That is a $100 job with the muffler out of the car.
Old Sep 29, 2009 | 11:41 AM
ysfg35's Avatar
mm is it better to clean them ?? and take out what inside the cats ???
Old Sep 30, 2009 | 05:06 AM
ysfg35's Avatar
?? any advise guys
Old Sep 30, 2009 | 10:50 AM
if you have something specific that you want to do ( material - design - etc ) no one can help as it is your idea, but If you want just to get rid of the cats here is your option:
1) just take off the factory cats and put the system back. This way you guarantee a good fitment and the cost will be lower for sure.
2) make your own pipe and weld it to the factory muffler. 2.5'' or 3'' no one really can help as it involves a lot of engineering regarding the air flow and heat transfer specially when NO one know what kind of material you are going to use and what design you have.
3) full straight system ( no cats - no muffler). As I understand money is an issue and you are trying to save ( we all do ), so Fabspeed bypass cats and bypass muffler is your best option. I have heard it in person and it was not bad at all but not the best for my taste. I had the bypass muffler pipes on my TT then switch to full cargraphic system and I will never go back to straight as I love how my car sound now. I do have the fabspeed pipes if you are interested ( cats and muffler ).
hope that help and PM sent
- Abdullah
Old Sep 30, 2009 | 12:51 PM
ysfg35's Avatar
ok thnx man ,, tommoro i will tell you what happen with me
Old Oct 1, 2009 | 10:04 AM
ysfg35's Avatar
guys i did it 2day ...
the car feels great .. no cell apear in the dash ...
the car reach 14psi faster then before .... no loud noise ....
