997 TT Engine Oil Overfill
Old Oct 12, 2009 | 05:32 PM
billkam's Avatar
billkam is infamous around these parts
I was wondering what is going to happen if you overfill your engine oil during an oil change?
I did mine myself and in the beginning I only put 7 quarts in the engine.
Then I started the car and waited for the engine to warm up.
I checked the oil level and showed half full.
I added about 3/4 of a quart and then checked again.
Now is always showing totally full.
The instructions I had showed 8.5 quarts needed for an oil change without the touching the oil in the Turbos.
I believe it should be OK but I am just wondering.
Old Oct 12, 2009 | 06:12 PM
bbywu's Avatar
If you were truly at one half and added 3/4 quart you're going to be fine...
Old Oct 12, 2009 | 08:21 PM
turbofal's Avatar
turbofal is infamous around these parts
should be fine as long as you didnt run it for too long.
COBB Tuning
Jan 1, 2025 09:02 AM
audipwr1
Sep 25, 2021 01:31 PM
Jul 29, 2019 11:13 AM
The Oss
Aug 24, 2015 08:19 PM
