? how long for flashed ECU to recognize race gas
Old Nov 3, 2009 | 03:47 PM
twturbo's Avatar
twturbo Is a GOD !twturbo Is a GOD !twturbo Is a GOD !twturbo Is a GOD !twturbo Is a GOD !twturbo Is a GOD !twturbo Is a GOD !twturbo Is a GOD !twturbo Is a GOD !twturbo Is a GOD !twturbo Is a GOD !
I have a Protomotive flashed ECU & from what i understand the ECU adjusts when you put in higher octane fuel which i can get 100 at the the pump & 109 locally,so how long it does it take is it 5 to 10 min or miles or more like an hr or 50 miles I see some software like Giac have a hand held device to instantly change octane ratings. Just wanna make sure i'm understanding how this works thanks.
Old Nov 3, 2009 | 04:08 PM
sleepys4's Avatar
sleepys4 is infamous around these parts
Great question.. I think the evomsit does the same thing.
Old Nov 3, 2009 | 04:17 PM
SpoolnV8's Avatar
SpoolnV8 is infamous around these parts
Good Question! I also wonder if the ignition timing will never be as aggressive as a dedicated High Octane map. I know that most computers learn your driving style and change mapping accordingly.
For Example: If I was to reset my 05' E55 ecu, the throttle would be more sensitive/aggressive and felt faster. After a Reset the car would loose traction but still very controllable through first gear. After a lil bit of driving it wouldn't do it again. Similiar results with a CL600 and stock Supra ECU's
Old Nov 10, 2009 | 10:28 PM
SpoolnV8's Avatar
OP did you ever get an answer to this?
Old Nov 10, 2009 | 10:46 PM
NeilM's Avatar
NeilM has a reputation beyond reputeNeilM has a reputation beyond reputeNeilM has a reputation beyond reputeNeilM has a reputation beyond reputeNeilM has a reputation beyond reputeNeilM has a reputation beyond reputeNeilM has a reputation beyond reputeNeilM has a reputation beyond reputeNeilM has a reputation beyond reputeNeilM has a reputation beyond reputeNeilM has a reputation beyond repute
right away. Just punch it. I did it this past weekend. The car had approx a half a tank of 91 octane and put in about 8 gallons of 100oct. The response was immediate. Timing, spooling, sound, etc. changes right away as soon as I punched it. I imagine if it was pure 100oct, it would be even more aggressive.
More aggressive timing, afr's, and boost maps so therefore, more power. I have the EVOMSit flash with exhaust, intake, and headers.
Old Nov 10, 2009 | 10:53 PM
M3 S3-R's Avatar
M3 S3-R is a jewel in the roughM3 S3-R is a jewel in the roughM3 S3-R is a jewel in the rough
If your tank is on empty with fuel light on, it should take about 10 to 15 minutes of freeway driving. I can notice a big differance running the 100 octane fuel.
Jul 29, 2019 11:13 AM
BlackMarketRacing
Dec 8, 2015 01:49 PM
Sep 1, 2015 03:16 PM
Aug 20, 2015 12:17 PM
Aug 19, 2015 06:55 PM
