DIY oil change Mezger M64 block engine M96/70 M97/70
bbywu - thanks a million for this post! I am going to attempt it this fall.
Just curious where this piece goes - 999 707 465 40 separate smaller O-ring?? I am having some issues locating this piece.
It goes on the oil filter....There is a small o ring that will be located once you pull the oil filter out....
BBYWU,
thanks for this helpful and complete procedure. I have a couple other bits of info that may be helpful to others. The size filter wrench needed is 76mm X 14 flute. I picked up one made by CTA at Pep Boys, model #A251 for about 6 bucks. A BTW: make sure the drain pan you use is an open container, not one that collects oil in the top and drains through a hole into the container. Being wise and looking ahead, instead of using my old reliable oil change materials, I decided to treat myself to a new oil drain container that holds 10 quarts. My first change gave me an "oh *!#*" as soon as I removed the drain bolt from the oil tank. Within about 5 seconds it looked like I'd struck Spindletop in East Texas. The size of the drain bolt on the 997 is so large that you get about 6-7 quarts of hot oil flowing out in a matter of seconds, which far exceeds the flow capacity of this new drain pan. All's well, except the EPA's on my ***....
Lift the car up with jackstand is a tough issue. I jack the car up and place a low profile ramp underneath. I suggest jack up the car from the passenger rear tire. Place the ramp and lower the car onto the ramp, and make sure it's secure. Then, drain the plugs. Wear a pair thin, used handyman gloves or leather gloves and cover them with plastic disposable gloves you get at costco and long sleeves shirt to protect yourself against the hot exhaust and oil. Perhaps get two wide open drain pans--one for the crankcase and the other for the aluminum oil pan. Jack the car off the ramp to the ground so that it's leveled. Wait for a few min and jack the car up onto the ramp again to secure the plugs back. The low car profile makes it difficult for the oil pan plug. I had a torque wrench and a 27 mm wrench together. Both are quite heavy, esp the torque wrench. When torquing, I was worried that the torque wrench might just drop and strip the bolt (which is cheap to replace) or the sudden unopposed force from the 27 mm wrench that could potentially damage the aluminum oil pan. So, I had my dad's hand to support the torque wrench to make sure it stayed connected to the bolt while I torqued it.
Other posts suggest loosening the oil filter cap before raising oil temp to operating temp because when hot it is tough to remove. I loosened mine one or two circles and monitored it with the engine lid up in case oil started to leak. No leak at all. Then, it was very easy to remove. I got some medical syringe and tube to suck the small amt of oil out and poured some new oil into the can to "pre-fill" the new filter. I bought the ?$35 Porsche wrench from Sunset (portland oregon) still in the mail. Can't wait, so went to Autozone to get the 75-77mm 14 flute. A tiny tiny bit on the larger side, but no marks on the oil cap at all after unscrewing and torquing it. $6 bucks.
Now, put new oil in. Regular round funnel won't fit!!! I had to cut an used BMW filter (mobil one filter mouth is too wide for the Porsche's oil feeder) and turned it side ways as a funnel with the help of my father to secure the funnel to the oil feeder. I need to shop for a long extension that actually work better. Any ideas? Because My father was holding the makeshift funnel, I dumped the oil quickly, and ended up using 9-1/3 qt for the bar to go to the top. Question: When topping off the oil, I shut the engine off, went back, 1/5 qt in, start the engine, and another 1/5 qt in. Could I have just left the cap off with the engine running and topping the oil off?? I was worried that the oil might have squirted out thru the not so tightly sealed oil feeder (I didn't think I needed to shut off the engine, but, I wanted to be on the safe side)
My first Porsche and 1st oil change on a Porsche. Took a little longer than necessary, but avoided major potential damages.
If you drain bot the crankcase and oil tank does this drain the turbos?
Also do you have to use a syringe to remove left over oil? should you do this?
A few more pictures of this process would be great!
is it the same procedure for the 996 turbos?
I have 26k on my 2007 Turbo and have changed the oil every time (at 1000 miles and every 5000 miles). When you undo the oil tank plug prepare yourself for a waterfall. The first time I did it i used one of those oil pans that have a little hole for drainage. Big mistake, you need at least a 12 qt container or better yet get 2... a 12qt and a 6qt for doing the crankcase. One thing I always do (because its a no no to overfill) is I measure the oil I remove from the car and add only that amount. I use 1 gallon plastic jugs to measure and usually extract about 8.5 - 9 quarts. It takes less than a 1/2 hour to do when you get the hang of it.
Ok this is truly a dumb question but there is only place to add oil (in the engine compartment)? The only reason I ask is because there is two oil reservoirs (crancase and oil tank). Thanks
Diff for 996 TT. I change mine every 6 months or 1000 miles. Make sure you have an oil pan that can handle the volumn and flow. You get all 6-7 quarts of sump oil in 10 seconds or less.
Only one way in.
