launch control
Old Dec 18, 2009 | 06:00 AM
semih's Avatar
semih is infamous around these parts
launch control
Hello,
Does the gen 2 turbo manuel shifter have a launch control like the gt2? If not why didn't they do it , because they have the technology.
Is it a marketing thing to promote the pdk.
Thanks.
Old Dec 18, 2009 | 10:34 PM
Porsche917's Avatar
Porsche917 is a splendid one to beholdPorsche917 is a splendid one to beholdPorsche917 is a splendid one to beholdPorsche917 is a splendid one to beholdPorsche917 is a splendid one to beholdPorsche917 is a splendid one to behold
probably because there is a lot more stress on the clutch when launching an all wheel drive car over a two wheel drive car.
Old Dec 18, 2009 | 11:44 PM
turbo498's Avatar
turbo498 is infamous around these parts
keep in mind that the PDK transmission has a dual clutch while the normal manual gear has a single clutch . I've heard that you can use the launch control feature on the PDK with no limit. It wont even cause wear/tear to your clutch !! but thats due to the dual clutch technology.
Old Dec 19, 2009 | 12:38 PM
Porsche917's Avatar
It is actually a multidisc wet clutch setup where there are multiple clutch discs on each shaft, this is going to have more surface area to spread the load over compared to a single disc conventional manual, It is also bathed in oil which is going to provide cooling. Plus safeguards are built into the software on the PDK to protect itself from destruction.
Old Dec 19, 2009 | 12:40 PM
Porsche917's Avatar
every manual transmission porsche has launch control.... its called your right foot
Old Dec 20, 2009 | 06:35 AM
semih's Avatar
thanks, for the explication. But what is the best way to launch a manual without damaging the clutch. How many revs?
Rguy
Apr 12, 2020 11:11 PM
rohnin
Sep 7, 2015 01:10 PM
MrJoshua
Sep 6, 2015 02:06 PM
