Warming up a 997 TT
Old Dec 27, 2009 | 04:35 PM
ZZinger's Avatar
ZZinger is just really niceZZinger is just really niceZZinger is just really niceZZinger is just really niceZZinger is just really nice
Warming up a 997 TT
I just received 20" of snow in my area last week so my TT does not go out till the weather and the roads clear up. Is it ok to start the car and let it get up to temperature in my garage for 10 -15 minutes or is that bad for the car?? I rarely drive in the winter, but I like to start it and let it run a bit if I don't drive my TT for a few weeks for the battery/ and systems to run etc...
Old Dec 27, 2009 | 05:56 PM
2006GT's Avatar
2006GT is infamous around these parts
that's not a bad idea. i would take it out too, when most of the snow clears. tt does fine in the snow
Old Dec 27, 2009 | 06:08 PM
rvhpno80's Avatar
rvhpno80 Is a GOD !rvhpno80 Is a GOD !rvhpno80 Is a GOD !rvhpno80 Is a GOD !rvhpno80 Is a GOD !rvhpno80 Is a GOD !rvhpno80 Is a GOD !rvhpno80 Is a GOD !rvhpno80 Is a GOD !rvhpno80 Is a GOD !rvhpno80 Is a GOD !
I do it, all the time, in new york we had about 12-16 inches, i warm her up once a week, thats why it is good to make sure you have a full gas tank when a winter storm is coming your way...
Old Dec 27, 2009 | 06:25 PM
mto's Avatar
mto
mto has much to be proud ofmto has much to be proud ofmto has much to be proud ofmto has much to be proud ofmto has much to be proud ofmto has much to be proud ofmto has much to be proud ofmto has much to be proud ofmto has much to be proud of
I would just let it sit until you can drive the car for at least 30 minutes allowing mechanicals to reach operating temps. Have the car sitting for weeks or even months when properly stored with a trickle charger is not a big deal.
Just starting and idling for say 20 minutes still does not allow the engine to warm properly (no load), and you will be causing unnecessary condensation to get mixed into your oil.
Old Dec 27, 2009 | 06:43 PM
handdoc's Avatar
handdoc is infamous around these parts
get a porsche charger that just plugs into the cig socket...i blast mine around when the roads are dry
Old Dec 27, 2009 | 10:22 PM
ZZinger's Avatar
That was my concern mto, condensation in the oil? can you elaborate...Is this due to the fact that the engine gets up to temperature but without "running" the car it can be a bad thing with no load. Does this occur over time or every time it is warmed without a load?
Old Dec 27, 2009 | 11:47 PM
DVDT's Avatar
DVDT is infamous around these parts
As mto said, best to warm up under load (moderate). Condensation occurs in cylinders since water is a product of combustion, also fuel mixture is rich when cold and thus fuel can mix with oil in cylinders. These contaminants get past rings and need sustained elevated oil temps to evaporate. As was suggested, a trickle charger is the better way to go until you can drive it long enough for oil temp to get to normal range.
SRC4S
Sep 1, 2015 09:22 AM
ritchrwi
Aug 29, 2015 08:27 PM
PelicanParts.com
997 Vendor Classifieds
Aug 20, 2015 02:39 PM
PelicanParts.com
997 Turbo Vendor Classifieds
Aug 20, 2015 02:38 PM
PelicanParts.com
Aug 18, 2015 03:41 PM
