Carbonetic or Sachs for Clutchs ?
Old Feb 24, 2010 | 07:32 PM
Nasser's Avatar
Nasser has a brilliant futureNasser has a brilliant futureNasser has a brilliant futureNasser has a brilliant futureNasser has a brilliant futureNasser has a brilliant futureNasser has a brilliant futureNasser has a brilliant futureNasser has a brilliant futureNasser has a brilliant futureNasser has a brilliant future
hi , im wondering witch one is Better
Carbonetic
http://www.carbonetic.net/products/twinandtriple.html
or
Sachs Performance
http://www.sachsperformance.com/EU/s...lung-set-2.htm
Your recommends ?
Old Feb 24, 2010 | 08:16 PM
bbywu's Avatar
What are your requirements? How much HP/torque do you need to hold? How important is clutch engagement and feel? Are you going to remove the hydraulic assist or not?
Old Feb 24, 2010 | 09:48 PM
Nasser's Avatar
700 awhp + , i dont need it to be very hard to use , i need it soft and easy to use
why i have to remove the hydraulic assist ?
Old Feb 24, 2010 | 10:20 PM
bbywu's Avatar
Some upgraded clutches have engagement points that are much smaller, meaning your ability to modulate the friction point is limited to a smaller range. The hydraulic assist removes some of the driver's feel of the pedal. Removing the assist allows the driver to have a better feel of the engagement point.
You should also consider posting this on the 996TT forum as the clutch systems are the same. There are far more users in that HP range on the 996TT platform, who will be able to give you advice.
Old Feb 25, 2010 | 07:18 AM
robertp's Avatar
robertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud of
I run the carbonetics Triple disk with the LWFW. Great clutch.
Old Feb 25, 2010 | 11:29 AM
GotBoost?'s Avatar
GotBoost? Is a GOD !GotBoost? Is a GOD !GotBoost? Is a GOD !GotBoost? Is a GOD !GotBoost? Is a GOD !GotBoost? Is a GOD !GotBoost? Is a GOD !GotBoost? Is a GOD !GotBoost? Is a GOD !GotBoost? Is a GOD !GotBoost? Is a GOD !
At 700hp, the Sachs setup will probably not be enough. I had the Sach's stage 2 clutch with the LWFW and it could not hold the power on my car. I just got it replaced with a Clutch Masters stage 2 clutch with a stage 3 pressure plate. 3900lb of clamping force. This is a Fiber Tough/ Organic disc that gives you almost stock drivability. CLutch Masters claim that is will hold over 800hp.
http://www.clutchmasters.com/shop/?p...98&ToYear=2004
Old Feb 25, 2010 | 04:42 PM
bbywu's Avatar
Even with an upgraded pressure plate (883082 999764) I don't think the Sachs setup will hold up long to 700 AWHP
drug delivery
Oct 24, 2015 11:04 PM
ELMEL
Sep 28, 2015 01:12 PM
bongnation
Sep 25, 2015 02:58 PM
ECS Tuning - BMW
Sep 16, 2015 07:20 AM
ECS Tuning - VW
Sep 9, 2015 12:01 PM
