Rough Idle
Old Feb 25, 2010 | 09:39 PM
raiyu's Avatar
raiyu is a splendid one to beholdraiyu is a splendid one to beholdraiyu is a splendid one to beholdraiyu is a splendid one to beholdraiyu is a splendid one to beholdraiyu is a splendid one to beholdraiyu is a splendid one to behold
Rough Idle
Hey guys driving on my way to work today my car developed a really rough idle. RPMs fluctuate around 650-750 and the car keeps burping. On one stop light the car completely stalled.
I had a check engine light on from my exhaust (never been an issue before) and my check engine light didnt start blinking.
The car drives ok, after about 2k RPMs, any ideas on what this could be? I was told maybe a boost hose was loose?
thx.
Old Feb 25, 2010 | 10:07 PM
flash68's Avatar
flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !
Sounds similar to the symptoms I had when my inlet piping was loose/disconnected...
Old Feb 25, 2010 | 10:10 PM
raiyu's Avatar
With the bad snow we are getting hammered with today and tomorrow may not be able to get the car to the shop till Monday, is there any damage from driving it in this condition as long as I dont do WOT and boost?
Old Feb 25, 2010 | 10:26 PM
TT Surgeon's Avatar
Might be your plugs, run a scanner the codes will pop up. You can borrow mine if you want, I'm in the city tomorrow.
c
Old Feb 26, 2010 | 04:07 AM
ysfg35's Avatar
ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !
there is a hose in the vacum ,, not connected ...
Old Feb 26, 2010 | 07:49 AM
raiyu's Avatar
Thanks for the offer Im going to leave the car at home today and try to make it out to TKX tomorrow morning if possible. Hope its just a quick and easy fix.
Old Feb 26, 2010 | 08:19 AM
Arone997tt's Avatar
Arone997tt has much to be proud ofArone997tt has much to be proud ofArone997tt has much to be proud ofArone997tt has much to be proud ofArone997tt has much to be proud ofArone997tt has much to be proud ofArone997tt has much to be proud ofArone997tt has much to be proud ofArone997tt has much to be proud ofArone997tt has much to be proud of
i have the same problem its the hose @ plenum y-pipe, pain in the a-- to get to, it's throwing all kinds of codes this is the 2nd time for me.
Old Feb 28, 2010 | 07:44 AM
raiyu's Avatar
The code was related to the left cam shaft timing. Looks like its not a piping issue. Wont know 100% till Monday and the car is 4,000 miles out of warranty. Hope its nothing more serious than a cam shaft sensor that needs replacing. We'll see.
Old Feb 28, 2010 | 07:56 AM
imcarnuts's Avatar
imcarnuts Is a GOD !imcarnuts Is a GOD !imcarnuts Is a GOD !imcarnuts Is a GOD !imcarnuts Is a GOD !imcarnuts Is a GOD !imcarnuts Is a GOD !imcarnuts Is a GOD !imcarnuts Is a GOD !imcarnuts Is a GOD !imcarnuts Is a GOD !
WOW - An '08 that is 4000 miles out of warranty. Hope all works out well with the car and it is only a minor problem.
Old Mar 1, 2010 | 08:46 AM
raiyu's Avatar
Its a broken left cam shaft, needs engine out work to be replaced.
Old Mar 1, 2010 | 12:22 PM
NJR911's Avatar
NJR911 is infamous around these parts
Hopefully you will get some goodwill to help with your problem. Good Luck!
agentsmurf
Cayenne 955/957
Oct 17, 2015 02:10 AM
007 Vantage
Oct 8, 2015 08:35 PM
freddiemac
Oct 7, 2015 11:05 AM
TOGWT
Detailing
Oct 1, 2015 07:59 AM
PelicanParts.com
911
Sep 28, 2015 04:26 PM
