Check engine light problem
Old Feb 28, 2010 | 03:47 AM
Kai611168's Avatar
Kai611168 is infamous around these parts
Hey guys, i just installed a fabspeed V3 exhaust with 200cell cat on my 08 TT, and i am having the check engine light problems, I am running the lim mode which only allow me to go up to 0.6bar. I tried to take off the battery for 5 mins and let it reset but it doesnt work. Anyone else have the same problem? Do i need to reset the computer inorder to solve the problem
Old Feb 28, 2010 | 04:33 AM
ysfg35's Avatar
ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !
you need a flash ..
Old Feb 28, 2010 | 07:10 AM
venkatreddytx's Avatar
venkatreddytx has a reputation beyond reputevenkatreddytx has a reputation beyond reputevenkatreddytx has a reputation beyond reputevenkatreddytx has a reputation beyond reputevenkatreddytx has a reputation beyond reputevenkatreddytx has a reputation beyond reputevenkatreddytx has a reputation beyond reputevenkatreddytx has a reputation beyond reputevenkatreddytx has a reputation beyond reputevenkatreddytx has a reputation beyond reputevenkatreddytx has a reputation beyond repute
Either a flash or O2 sensor extension\simulators will fix this, on mine Softronic flash fixed it.
Old Feb 28, 2010 | 09:37 AM
ysfg35's Avatar
yes me too ,, softronic will do it
pm dan in vividracing he will give you great price
good luck
Old Feb 28, 2010 | 09:49 AM
bbywu's Avatar
You should not require a software flash to make a standard aftermarket exhaust with 200 cell cats work. What code is the CEL showing?
Old Feb 28, 2010 | 10:20 AM
gu9cci's Avatar
gu9cci has a reputation beyond reputegu9cci has a reputation beyond reputegu9cci has a reputation beyond reputegu9cci has a reputation beyond reputegu9cci has a reputation beyond reputegu9cci has a reputation beyond reputegu9cci has a reputation beyond reputegu9cci has a reputation beyond reputegu9cci has a reputation beyond reputegu9cci has a reputation beyond reputegu9cci has a reputation beyond repute
i have the same issue after mine and was coilpacks.when i rev the car over 5000 rpm i get cel and misfire
Old Feb 28, 2010 | 11:25 AM
Porsche Boy's Avatar
Porsche Boy is a jewel in the roughPorsche Boy is a jewel in the roughPorsche Boy is a jewel in the rough
If you have a 200 cell exhaust you do NOT need a flash to get rid of the cell. High quality 200 cell cats are not suppose to give you a cell as far as I know, 100 cells and bypass will. You either have a faulty cat or something else is wrong.
Old Feb 28, 2010 | 01:23 PM
TT Surgeon's Avatar
Exactly right, you have bad cats.
Old Feb 28, 2010 | 06:20 PM
I have been reading where HJS 200 cell cats shouldn't cause CEL on the contrary I have read threads like this that they do cause CEL.
From what I read Fabspeed uses HJS cats.
I read a thread where FVD exhaust caused a CEL to show up and a flash fixed it.
My personal opinion is that 200 Cell cats will cause CEL to show up.
It is a good idea to read out the code to make sure you are getting it due to
"Catalytic Inefficiency Code" and not something else.
Old Mar 1, 2010 | 12:00 AM
ruf_turbo's Avatar
ruf_turbo Is a GOD !ruf_turbo Is a GOD !ruf_turbo Is a GOD !ruf_turbo Is a GOD !ruf_turbo Is a GOD !ruf_turbo Is a GOD !ruf_turbo Is a GOD !ruf_turbo Is a GOD !ruf_turbo Is a GOD !ruf_turbo Is a GOD !ruf_turbo Is a GOD !
My car has been running a 100 cell Europipe for almost 3 years and never had a CEL on it. And it wasn't flashed for it either.
That's exactly what should be done rather than assuming it's one thing or another. CEL covers a WHOLE lot of things.
Old Mar 1, 2010 | 12:48 AM
TTdude's Avatar
TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !
Originally Posted by tt surgeon
exactly right, you have bad cats.
+1 ^^
Old Mar 1, 2010 | 02:34 AM
milou's Avatar
milou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond repute
I'm also running on 100cel Europipe, i had it for a few months without flashing it and never had a problem, plus it sounds great
Old Mar 4, 2010 | 08:30 AM
vividracing's Avatar
Most 200cell cats throw a CEL from a cat inefficiency. The light does nothing but look annoying. You can keep turning it off, or spend the extra money on the ECU Flash which raises the 02 limit so you dont have this problem and gives you an extra 60+HP
www.vrtuned.com
Old Mar 4, 2010 | 12:35 PM
Kai611168's Avatar
thanks for the comments and helps guys, problem solved
Old Mar 4, 2010 | 01:53 PM
TT Surgeon's Avatar
I had FS without HJS cats, CELs constantly. Switched to HJS, no CELs.
I have since gone with FVD, no CELs ever.
