Broken Cam Shaft :(
Old Mar 1, 2010 | 04:52 PM
nevert00fast's Avatar
nevert00fast is infamous around these partsnevert00fast is infamous around these parts
Originally Posted by yalmutawa
its a metal we call it the bone it cant be broken trust me !
It's hard to break the camshaft, but it's easier to damage the surface of the lobes.
Old Mar 1, 2010 | 06:28 PM
dtakenname's Avatar
dtakenname is infamous around these parts
Isn't it possible to use durametric to engage and disengage the variocam
(cam position sensor solenid) so you can check it?
Old Mar 1, 2010 | 07:39 PM
Jonnydeep83's Avatar
Jonnydeep83 is infamous around these parts
Had my Cam replaced (bank2) under warranty at 16k, something about one of the pieces inside blocking oil flow. Got camshaft position error codes . Porsche replaced under warranty , p.s. the warranty bill was aroun 9k. I know i am not the only one my particular issue happened too.
Old Mar 1, 2010 | 08:16 PM
This sounds like the same issue that you had.
https://www.6speedonline.com/forums/...rbo-3076r.html
Old Mar 1, 2010 | 09:27 PM
QUIK 911's Avatar
QUIK 911 is a splendid one to beholdQUIK 911 is a splendid one to beholdQUIK 911 is a splendid one to beholdQUIK 911 is a splendid one to beholdQUIK 911 is a splendid one to beholdQUIK 911 is a splendid one to beholdQUIK 911 is a splendid one to behold
hopefully its just a cam timing sensor. I had both of my sensors replaced when I did my AWE turbo upgrade only to have one go bad after 100o miles. Ended up putting one of the old sensors in and its been good since. shouldn't take the dealer more then 1 hour to change a sensor that cost less then 100 bucks. Good Luck
Old Mar 1, 2010 | 09:36 PM
yalmutawa's Avatar
yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !
keithta a member in the forum had the same issue as our frnd 'never00fast mentioned
Old Mar 1, 2010 | 10:04 PM
TT Surgeon's Avatar
I think you're looking at a new cam, I would try like hell to get some kind of goodwill, at least a sizable discount.
Old Mar 2, 2010 | 09:16 AM
turbonator's Avatar
turbonator is infamous around these parts
Keep us posted as to whether Porsche comes through for you, especially considering it's only 4k mi out of warranty
Old Mar 2, 2010 | 09:21 AM
art4iza's Avatar
art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !
I've heard of this also but not very common. Yes, Keith had the same issue and resolved it with Todd K. Let us know the progress. GL
Old Mar 2, 2010 | 03:10 PM
raiyu's Avatar
raiyu is a splendid one to beholdraiyu is a splendid one to beholdraiyu is a splendid one to beholdraiyu is a splendid one to beholdraiyu is a splendid one to beholdraiyu is a splendid one to beholdraiyu is a splendid one to behold
They got a chance to swap the sensors and the code changed. They are getting new sensors from the dealership tomorrow morning so they'll be able to put on new sensors and see if the problem goes away entirely.
Fingers crossed and optimistic that its just that simple!
Old Mar 2, 2010 | 07:32 PM
art4iza's Avatar
If it was just the sensor then that's awesome news. Keep'em crossed dude.
Old Mar 2, 2010 | 09:17 PM
Yup that sounds exactly like the issue i had!! .. stinks that I got the broken one :P
Old Mar 3, 2010 | 07:16 AM
Glad you got it covered under warranty. I hope these are isolated issues that's not associated with cars with some mileage on them.
Old Mar 3, 2010 | 02:45 PM
raiyu's Avatar
They got the new cam sensors in today and put em in and fired up the engine and no codes came up. They are going to finish assembling the rest of the engine and then put some miles on it tomorrow morning and I should be able to pick it up before noon.
So it looks like the cam itself is ok. Phew, wasn't looking forward to a huge repair bill
Old Mar 3, 2010 | 02:54 PM
M3 S3-R's Avatar
M3 S3-R is a jewel in the roughM3 S3-R is a jewel in the roughM3 S3-R is a jewel in the rough
Good to know that things turned out okay for you.
