Tyre pressure
Old Mar 3, 2010 | 05:09 PM
darmawaa's Avatar
darmawaa is infamous around these partsdarmawaa is infamous around these parts
Tyre pressure
Why does my tyre pressure meter always read 3psi lower than actual?
I pump the tyres to 34Front/39Rear according to manual. I test this number using several tyres gauge so it must be correct number.
But the display monitor (MID) in the car reads 31psi Front/ 36psi Rear, so there is pressure low warning.
If I reset the tyre pressure in the MID in this pressure reading, would the low pressure warning dissapear?
What is the use of reset tyre pressure after inflating tyres?
Old Mar 3, 2010 | 05:58 PM
imcarnuts's Avatar
imcarnuts Is a GOD !imcarnuts Is a GOD !imcarnuts Is a GOD !imcarnuts Is a GOD !imcarnuts Is a GOD !imcarnuts Is a GOD !imcarnuts Is a GOD !imcarnuts Is a GOD !imcarnuts Is a GOD !imcarnuts Is a GOD !imcarnuts Is a GOD !
There have been other threads about this. Pretty much standard that they read about 3 psi low.
Old Mar 3, 2010 | 07:12 PM
darmawaa's Avatar
What is the best hot and cold tyre pressure for track?
Old Mar 4, 2010 | 04:17 PM
997TTurbo's Avatar
997TTurbo is a splendid one to behold997TTurbo is a splendid one to behold997TTurbo is a splendid one to behold997TTurbo is a splendid one to behold997TTurbo is a splendid one to behold997TTurbo is a splendid one to behold997TTurbo is a splendid one to behold997TTurbo is a splendid one to behold
I have a 2007 Turbo and my tire pressure guage on the dash is always off by 3 lbs also!
Once tires warm up and your dash guage shows 33 front and 39 rear, you are OK. Real pressure is going to be 36 front, 42 rear. Seems to be a common issue
Old Mar 4, 2010 | 08:12 PM
NeilM's Avatar
NeilM has a reputation beyond reputeNeilM has a reputation beyond reputeNeilM has a reputation beyond reputeNeilM has a reputation beyond reputeNeilM has a reputation beyond reputeNeilM has a reputation beyond reputeNeilM has a reputation beyond reputeNeilM has a reputation beyond reputeNeilM has a reputation beyond reputeNeilM has a reputation beyond reputeNeilM has a reputation beyond repute
I run Michelin PS Cups at the track.
Cold: 32 Fronts, 36 rears
Hot: 36 fronts, 40 rears
ModBargains.com
996 Turbo Vendor Classifieds
Oct 1, 2015 11:48 AM
