When changing wheels,TPMS still operates?
Old Mar 22, 2010 | 05:23 PM
skandalis447's Avatar
skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !
Tomorrow probably i will get a set of dymag wheels...However i want to keep TPMS sensors that make our lives easier...Are they transferrable from one wheel to another?
Old Mar 22, 2010 | 05:35 PM
ishmerc's Avatar
ishmerc is infamous around these parts
yes they are ,I did it on my car .
Old Mar 22, 2010 | 05:52 PM
So you just remove the sensors from OEM wheels and install them on aftermarket?
Old Mar 22, 2010 | 06:04 PM
Wheel Studio's Avatar
Wheel Studio is a splendid one to beholdWheel Studio is a splendid one to beholdWheel Studio is a splendid one to beholdWheel Studio is a splendid one to beholdWheel Studio is a splendid one to beholdWheel Studio is a splendid one to beholdWheel Studio is a splendid one to behold
Yes, sometimes they're tricky to remove without breaking them, but your aftermarket wheels should be drilled to accept your OEM TPMS sensors. If they're not, your wheel retailer should be able to provide you with brackets that relocate the sensors inside the barrel.
Old Mar 22, 2010 | 09:45 PM
ruf_turbo's Avatar
ruf_turbo Is a GOD !ruf_turbo Is a GOD !ruf_turbo Is a GOD !ruf_turbo Is a GOD !ruf_turbo Is a GOD !ruf_turbo Is a GOD !ruf_turbo Is a GOD !ruf_turbo Is a GOD !ruf_turbo Is a GOD !ruf_turbo Is a GOD !ruf_turbo Is a GOD !
If you are planning on keeping the other set of wheels, you can buy new OEM (Beru) sensors and valve stems for under $400/set.
Old Mar 22, 2010 | 10:10 PM
TT Surgeon's Avatar
Yes, just switch from oem to the new wheels. The system will relearn the sensors, helps to to RF to RF, etc.
Old Mar 22, 2010 | 10:43 PM
twturbo's Avatar
twturbo Is a GOD !twturbo Is a GOD !twturbo Is a GOD !twturbo Is a GOD !twturbo Is a GOD !twturbo Is a GOD !twturbo Is a GOD !twturbo Is a GOD !twturbo Is a GOD !twturbo Is a GOD !twturbo Is a GOD !
if you don't use the sensors you will get an warning light on the dash that won't go away
Old Mar 23, 2010 | 01:09 AM
I want to keep the sensors...So i have to drill my new dymags to install them?That is bad news...i thought i just remove them and bolt them (somehow) to aftermarket wheels...
Old Mar 23, 2010 | 08:41 AM
damon@tirerack's Avatar
Moderator
I would check with Dymag before buying these. There's no way I'd drill a carbon fiber barrel myself.
damon@tirerack.com
877-522-8473 ext. 4643
574-287-2345 ext. 4643
Or use this link:
Old Mar 23, 2010 | 09:37 AM
Is there any guide to install sensors?
Old Mar 23, 2010 | 09:58 AM
WheelB's Avatar
Site Sponsor
WheelB has a brilliant futureWheelB has a brilliant futureWheelB has a brilliant futureWheelB has a brilliant futureWheelB has a brilliant futureWheelB has a brilliant futureWheelB has a brilliant futureWheelB has a brilliant futureWheelB has a brilliant futureWheelB has a brilliant futureWheelB has a brilliant future
You dont have to drill the dymags your tpms will fit right in ! no problem i have done at least 15 sets and never an issue with tpms . same as your OEM wheels . call me if you need anything Ben
Wheels Boutique // 786 249 0127 // Sales@wheelsboutique.com
Follow us on YouTube: www.youtube.com/user/WheelsBoutique
Largest HRE Dealer In The World / Largest ANRKY Dealer / BBS Premium Dealer / TechArt Premium Dealer / Vorsteiner / Rotiform / Akrapovic / iPE / Novitec / Brabus / AC Schnitzer / Mansory / Brembo / RENNTech / Weistec / Tubi / Hamman / KW / H&R and tons more.
Old Mar 23, 2010 | 10:13 AM
Thank you...I did not buy them today due to this...i ll buy them tomorrow...
Old Mar 24, 2010 | 12:09 AM
ruf_turbo's Avatar
Usually you have to specify that the wheel is for TPMS.
Old Mar 24, 2010 | 02:10 AM
Alcyon's Avatar
Alcyon has a spectacular aura aboutAlcyon has a spectacular aura about
Yes, here is some:
http://www.beru.com/download/produkt...tung_tss_e.pdf
Old Mar 24, 2010 | 07:52 AM
phthom's Avatar
phthom is infamous around these parts
There are ways around having tpms lights illuminated w/ sensors removed. I cut a 4" piece of pvc to fit snug, wrapped sensors in bubble wrap, drilled the pvc for a tire valve and hid the psudo pipe bomb in the trunk. I can't stand tpms
