Please help! Clutch fluid leaked.
Old Apr 2, 2010 | 12:48 AM
Abby997TT's Avatar
Abby997TT has a spectacular aura aboutAbby997TT has a spectacular aura aboutAbby997TT has a spectacular aura about
Hello Guys,
I have noticed some fluid on the floor by driver side front.
When i got home, i took the cover off the driver side front. sure enough, fluid all over the place because the cap was lose . Edit, reservor is still full and seems like fluid was being pushed out . oh btw, the fluid is in light green color.
The clutch works fine, what should i do now? I know clutch fluid is really bad on paint, Can i just hose off that area? Do i have to bleed the clutch or just top it off before i take it to the dealer?
Thanks guys!
Here are some pictures: IS IT CLUTCH FLUID?
Edit: guys i did more search, and looks like it's hydraulic fluid for power steering?
Old Apr 2, 2010 | 03:59 AM
Alcyon's Avatar
Alcyon has a spectacular aura aboutAlcyon has a spectacular aura about
This slave cylinder failure comes oem with almost every Turbo, there are a lot of threads about it, for instance this:
http://forums.rennlist.com/rennforum...ml#post6057529
mine was repaired under warranty. No problem if you drive with it. Liquid is Pentosin
Old Apr 2, 2010 | 06:12 AM
jjbravo's Avatar
jjbravo Is a GOD !jjbravo Is a GOD !jjbravo Is a GOD !jjbravo Is a GOD !jjbravo Is a GOD !jjbravo Is a GOD !jjbravo Is a GOD !jjbravo Is a GOD !jjbravo Is a GOD !jjbravo Is a GOD !jjbravo Is a GOD !
Bad slave... +1
Old Apr 2, 2010 | 08:49 AM
summoboy's Avatar
summoboy is just really nicesummoboy is just really nicesummoboy is just really nicesummoboy is just really nicesummoboy is just really nice
yep i had this - bad slave. dealer replaced under warranty. But they did not clean up the spilled fluid on wires,etc. - i had to do that.
Old Apr 2, 2010 | 02:53 PM
Abby997TT's Avatar
Thanks alot guys! I will book a time and take it in!
Old Apr 2, 2010 | 03:17 PM
gmoney's Avatar
I just picked up some pentosin to top up mine, going in Monday for the fix but I needed the car this weekend. Well known problem, should be a recall but Porsche perhaps is too proud.
That stuff is nasty, clean it all up asap. My cap does not tighten either.
jaehoppa
Oct 22, 2015 09:17 PM
the5
Oct 14, 2015 06:46 AM
sparks
Sep 8, 2015 03:03 PM
Saint Ari
Sep 4, 2015 03:30 PM
