PCM removal help
PCM removal help
Ok, don't want to break anything.
Removed the carpeted panels with torx.
Removed the 2 smaller torx screws for the side panels.
Side panels pop out at the middle/bottom, but are being held at the top, by what?!? I don't want to force it, but it doesn't want to pop out.
The are along the side of the PCM module on each side. You should see them along the edge of the left and right side.
The allen sockets are not bolts...they are plastic, take care turning them...they unlock an aluminum retaining spring.
ok, maybe I am still a step back.
I haven't been able to get the leather side pieces off. I took out the two screws for each, and the bottom and middle snap piece pop out, but something is holding the top of both in. Do I just need to pull harder? I think you're talking about the actual removal of the PCM, or.. am I missing something.
dension.. and yes I know I could do it up front, but i want to put it here for easy access to wiring ipod and BT later on.
I'm a goddamn EE that helped build a kit airplane, you'd think I could remove a damn radio, hehe.
This may help:
http://www.planet-9.com/reviews/showproduct.php?product=92&cat=5
Oh NOW you post that.. haha.. yup, there is my 7mm bolt!
Its out now. we're good to go. It's elegant once you know how to do it, but the bold is "ONCE YOU KNOW HOW TO DO IT".
