rebuilding the DFI engine
Old Apr 24, 2010 | 07:50 PM
dtakenname's Avatar
dtakenname is infamous around these parts
Hi,
May be I am missing something, but if the cylinders of the new DFI engine are welded to the crankcase, how is it possible to rebuild this engine?
Many Thanks.
Old Apr 25, 2010 | 09:52 AM
TT Surgeon's Avatar
Just either hone the cylinders, usually enough, or bore out and go with new pistons and larger displacement.
Old Apr 25, 2010 | 10:18 AM
dtakenname's Avatar
[quote=TT Surgeon;2815721]Just either hone the cylinders, usually enough, or bore out and go with new pistons and larger displacement.[/quote
What i don't understand is that, how is it possible to take the engine a part to begin with, or taking the pistons out. Lets compare the new engine to the old ones, in older engines first you take the heads out, and then the cylinders and pistons, and finally you get to open the crank case.
Now, lets say you take the heads out of the new DFI engine, now what? How are you going to take the pistons out? The cylinders must come out first, but they are welded to the case. Also there is no way to take the pistons out from the bottom of the engine. Once you take the heads out you cant go any further!!
If I am correct, how people and race teams are going to modify engines?
What if you are out of warranty?
Porsche is not going to supply engines more than ten years, then what?
Jul 29, 2019 11:13 AM
nlakind
Nov 6, 2015 10:15 AM
LiquidElephant
Aug 27, 2015 06:17 PM
The Oss
Aug 24, 2015 08:19 PM
